External eSata recognized but not mounted
I did some searching on the forum but somehow was not able to find the info I am looking for.
here is my problem :
I have a QNAP TS509pro with and external eSata enclosure connected for backup. This works fine.
When I disconnected the external device to swap it for another one (of the exact same brand, model, config (Raid 0) and disks ) the device is recognized but I am not able to mount / format the device.
I am afraid I have not properly unmounted the first eSata enclosure.... This happened before and I always end up with a lot of issues / problems connecting the enclosure again.
Rebooting the QNAP sometimes seems to help and with some luck the eSata Enclosure is mounted again / can be initialized for backups.
I found many reports of people having this issue but found no solutions.
Can anyone help me out and tell me what I have to do to "unmount" the already unmounted eSata device?
What SHH command can I use to find out which drive is my eSata and unmount / mount it manually?
Thx in advance!
tech info:
QNAP TS-509pro
Firmware 4.07
RAID 5
Thx in advance!
tech info:
QNAP TS-509pro
Firmware 4.07
RAID 5
Re: External eSata recognized but not mounted
Encountering a similar issue with my ts-509.
(FW 4.1.3)
I have a sandigital 4 drive esata enclosure in "spanning mode" to create one large disk.
I unmounted another esata drive improperly and now I can't get this one back online.
Looking for shell commands to help me mount this beast (12TB) so I can backup my nas.
(FW 4.1.3)
TS-509 Pro - Old School!
(FW 4.1.3)
I unmounted another esata drive improperly and now I can't get the sansdigital back online.
(FW 4.1.3)
- pwilson
Lets see what is actually mounted:Davide-NYC wrote:Encountering a similar issue with my ts-509.
(FW 4.1.3)
df -h | grep -v qpkg | grep -v grep
mount | grep -v qpkg | grep -v grep
ls -alF /share/external/
#done
Patrick M. Wilson
Victoria, BC Canada
[/share/external] # df -h | grep -v qpkg | grep -v grep
Filesystem Size Used Available Use% Mounted on
/dev/ramdisk 139.5M 111.9M 27.5M 80% /
tmpfs 64.0M 268.0k 63.7M 0% /tmp
tmpfs 499.7M 4.0k 499.6M 0% /dev/shm
/dev/sda4 371.0M 231.7M 139.3M 62% /mnt/ext
/dev/md9 509.5M 130.6M 378.9M 26% /mnt/HDA_ROOT
/dev/md0 10.7T 3.8T 7.0T 35% /share/MD0_DATA
[/share/external] # mount | grep -v qpkg | grep -v grep
/proc on /proc type proc (rw)
none on /dev/pts type devpts (rw,gid=5,mode=620)
sysfs on /sys type sysfs (rw)
tmpfs on /tmp type tmpfs (rw,size=64M)
tmpfs on /dev/shm type tmpfs (rw)
none on /proc/bus/usb type usbfs (rw)
/dev/sda4 on /mnt/ext type ext3 (rw)
/dev/md9 on /mnt/HDA_ROOT type ext3 (rw,data=ordered)
/dev/md0 on /share/MD0_DATA type ext4 (rw,usrjquota=aquota.user,jqfmt=vfsv0,user_xattr,data=ordered,delalloc,acl)
[/share/external] # ls -alF /share/external/
drwxrwxr-x 29 admin administ 1024 May 25 15:31 ./
drwxrwxr-x 32 admin administ 1024 May 25 15:32 ../
drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sda/
drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdb/
drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdc/
drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdd/
drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sde/
drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdf/
drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdg/
drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdh/
drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdi/
drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdj/
drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdk/
drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdl/
drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdm/
drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdn/
drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdo/
drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdp/
drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdq/
drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdr/
drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sds/
drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdt/
drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdu/
drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdv/
drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdw/
drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdx/
drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdy/
drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdz/
drwxr-xr-x 2 admin administ 1024 May 25 15:31 sdza/
[/share/external] # #done
- pwilson
That output wasn't very helpful unfortunately.Davide-NYC wrote:Code: Select all
[/share/external] # df -h | grep -v qpkg | grep -v grep Filesystem Size Used Available Use% Mounted on /dev/ramdisk 139.5M 111.9M 27.5M 80% / tmpfs 64.0M 268.0k 63.7M 0% /tmp tmpfs 499.7M 4.0k 499.6M 0% /dev/shm /dev/sda4 371.0M 231.7M 139.3M 62% /mnt/ext /dev/md9 509.5M 130.6M 378.9M 26% /mnt/HDA_ROOT /dev/md0 10.7T 3.8T 7.0T 35% /share/MD0_DATA [/share/external] # mount | grep -v qpkg | grep -v grep /proc on /proc type proc (rw) none on /dev/pts type devpts (rw,gid=5,mode=620) sysfs on /sys type sysfs (rw) tmpfs on /tmp type tmpfs (rw,size=64M) tmpfs on /dev/shm type tmpfs (rw) none on /proc/bus/usb type usbfs (rw) /dev/sda4 on /mnt/ext type ext3 (rw) /dev/md9 on /mnt/HDA_ROOT type ext3 (rw,data=ordered) /dev/md0 on /share/MD0_DATA type ext4 (rw,usrjquota=aquota.user,jqfmt=vfsv0,user_xattr,data=ordered,delalloc,acl) [/share/external] # ls -alF /share/external/ drwxrwxr-x 29 admin administ 1024 May 25 15:31 ./ drwxrwxr-x 32 admin administ 1024 May 25 15:32 ../ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sda/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdb/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdc/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdd/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sde/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdf/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdg/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdh/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdi/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdj/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdk/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdl/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdm/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdn/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdo/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdp/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdq/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdr/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sds/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdt/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdu/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdv/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdw/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdx/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdy/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdz/ drwxr-xr-x 2 admin administ 1024 May 25 15:31 sdza/ [/share/external] # #done
Please previde the output of:
dmesg
Patrick M. Wilson
Victoria, BC Canada
[~] # dmesg
Commit interval 5 seconds
[ 63.407618] EXT3-fs (sdc1): mounted filesystem with writeback data mode
[ 63.498364] kjournald starting. Commit interval 5 seconds
[ 63.500442] EXT3-fs (sdd1): mounted filesystem with writeback data mode
[ 63.586639] kjournald starting. Commit interval 5 seconds
[ 63.588774] EXT3-fs (sde1): mounted filesystem with writeback data mode
[ 63.748877] md: md9 stopped.
[ 63.780453] md: bind<sdb1>
[ 63.782739] md: bind<sdc1>
[ 63.785099] md: bind<sdd1>
[ 63.787460] md: bind<sde1>
[ 63.789737] md: bind<sda1>
[ 63.792655] bio: create slab <bio-1> at 1
[ 63.794685] md/raid1:md9: active with 5 out of 5 mirrors
[ 63.796811] created bitmap (65 pages) for device md9
[ 63.805975] md9: bitmap initialized from disk: read 5/5 pages, set 0 of 132512 bits
[ 63.818366] md9: detected capacity change from 0 to 542769152
[ 63.825490] md9: unknown partition table
[ 64.848442] kjournald starting. Commit interval 5 seconds
[ 64.898456] EXT3-fs (md9): using internal journal
[ 64.900547] EXT3-fs (md9): mounted filesystem with writeback data mode
[ 65.075934] md: md13 stopped.
[ 65.310583] md: bind<sdd4>
[ 65.312893] md: bind<sde4>
[ 65.315264] md: bind<sdc4>
[ 65.317598] md: bind<sda4>
[ 65.319874] md: bind<sdb4>
[ 65.322759] md/raid1:md13: active with 5 out of 5 mirrors
[ 65.324895] created bitmap (57 pages) for device md13
[ 65.332860] md13: bitmap initialized from disk: read 4/4 pages, set 0 of 114720 bits
[ 65.370803] md13: detected capacity change from 0 to 469893120
[ 65.381830] md13: unknown partition table
[ 66.614940] kjournald starting. Commit interval 5 seconds
[ 66.663566] EXT3-fs (md9): using internal journal
[ 66.665635] EXT3-fs (md9): mounted filesystem with writeback data mode
[ 85.088020] kjournald starting. Commit interval 5 seconds
[ 85.139243] EXT3-fs (md9): using internal journal
[ 85.141244] EXT3-fs (md9): mounted filesystem with ordered data mode
[ 111.905789] kjournald starting. Commit interval 5 seconds
[ 111.950344] EXT3-fs (md13): using internal journal
[ 111.952367] EXT3-fs (md13): mounted filesystem with writeback data mode
[ 122.546812] cryptodev: driver 0.9 loaded.
[ 122.737791] generic-usb 0003:051D:0002.0001: hiddev0: USB HID v1.00 Device [American Power Conversion Back-UPS RS 700G FW:856.L1 .D USB FW:L1 ] on usb-0000:00:1d.1-1/input0
[ 122.751141] usbcore: registered new interface driver usbhid
[ 122.753297] usbhid: USB HID core driver
[ 122.782834] Register ICH/PCH RTC driver.
[ 122.800547] iTCO_vendor_support: vendor-support=0
[ 122.831039] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 122.847054] iTCO_wdt: Found a ICH7 or ICH7R TCO device (Version=2, TCOBASE=0x0860)
[ 122.853207] iTCO_wdt: initialized. heartbeat=120 sec (nowayout=0)
[ 122.877246] usbcore: registered new interface driver usblp
[ 122.892960] jnl: driver (lke_9.2.0 QNAP, LBD=ON) loaded at f8918000
[ 122.918439] ufsd: module license 'Commercial product' taints kernel.
[ 122.920600] Disabling lock debugging due to kernel taint
[ 122.942482] ufsd: driver (lke_9.2.0 QNAP, build_host("BuildServer47-1"), acl, ioctl, bdi, sd2(0), fua, bz, rsrc) loaded at f89b4000
[ 122.942485] NTFS support included
[ 122.942487] Hfs+/HfsJ support included
[ 122.942488] optimized: speed
[ 122.942489] Build_for__QNAP_Atom_x86_k3.4.6_2014-12-15_lke_9.2.0_r245986_b56
[ 122.942491]
[ 123.110046] fnotify: Load file notify kernel module.
[ 124.279103] usbcore: registered new interface driver snd-usb-audio
[ 124.304119] usbcore: registered new interface driver snd-usb-caiaq
[ 124.338667] Linux video capture interface: v2.00
[ 124.412591] usbcore: registered new interface driver uvcvideo
[ 124.414955] USB Video Class driver (1.1.1)
[ 124.732326] 8021q: 802.1Q VLAN Support v1.8
[ 126.147753] tg3 0000:04:00.0: irq 44 for MSI/MSI-X
[ 126.192640] tg3 0000:03:00.0: irq 45 for MSI/MSI-X
[ 129.840103] tg3 0000:04:00.0: eth0: Link is up at 1000 Mbps, full duplex
[ 129.840299] tg3 0000:04:00.0: eth0: Flow control is on for TX and on for RX
[ 137.637292] kjournald starting. Commit interval 5 seconds
[ 137.645587] EXT3-fs (md9): using internal journal
[ 137.648144] EXT3-fs (md9): mounted filesystem with ordered data mode
[ 144.442469] md: bind<sda2>
[ 144.445834] md/raid1:md5: active with 1 out of 1 mirrors
[ 144.448365] md5: detected capacity change from 0 to 542851072
[ 145.454628] md5: unknown partition table
[ 147.529187] Adding 530124k swap on /dev/md5. Priority:-1 extents:1 across:530124k
[ 151.540138] md: bind<sdb2>
[ 151.565195] RAID1 conf printout:
[ 151.565201] --- wd:1 rd:2
[ 151.565206] disk 0, wo:0, o:1, dev:sda2
[ 151.565211] disk 1, wo:1, o:1, dev:sdb2
[ 151.565669] md: recovery of RAID array md5
[ 151.568191] md: minimum _guaranteed_ speed: 5000 KB/sec/disk.
[ 151.570683] md: using maximum available idle IO bandwidth (but not more than 200000 KB/sec) for recovery.
[ 151.573300] md: using 128k window, over a total of 530128k.
[ 153.797076] md: bind<sdc2>
[ 155.939064] md: bind<sdd2>
[ 156.840571] md: md0 stopped.
[ 156.862034] md: md0 stopped.
[ 157.116554] md: bind<sdb3>
[ 157.119351] md: bind<sdc3>
[ 157.122048] md: bind<sdd3>
[ 157.124671] md: bind<sde3>
[ 157.127238] md: bind<sda3>
[ 157.130327] md/raid:md0: device sda3 operational as raid disk 0
[ 157.132506] md/raid:md0: device sde3 operational as raid disk 4
[ 157.134649] md/raid:md0: device sdd3 operational as raid disk 3
[ 157.136761] md/raid:md0: device sdc3 operational as raid disk 2
[ 157.138812] md/raid:md0: device sdb3 operational as raid disk 1
[ 157.140832] NR_STRIPES is 4096 for total 255822 ram pages
[ 157.154216] md/raid:md0: allocated 84464kB
[ 157.156300] md/raid:md0: raid level 5 active with 5 out of 5 devices, algorithm 2
[ 157.158297] RAID conf printout:
[ 157.158299] --- level:5 rd:5 wd:5
[ 157.158304] disk 0, o:1, dev:sda3
[ 157.158307] disk 1, o:1, dev:sdb3
[ 157.158310] disk 2, o:1, dev:sdc3
[ 157.158313] disk 3, o:1, dev:sdd3
[ 157.158316] disk 4, o:1, dev:sde3
[ 157.158374] md0: detected capacity change from 0 to 11995945107456
[ 158.143639] md: bind<sde2>
[ 158.273268] md0: unknown partition table
[ 161.256752] md: md5: recovery done.
[ 161.296898] RAID1 conf printout:
[ 161.296902] --- wd:2 rd:2
[ 161.296906] disk 0, wo:0, o:1, dev:sda2
[ 161.296909] disk 1, wo:0, o:1, dev:sdb2
[ 161.306634] RAID1 conf printout:
[ 161.306637] --- wd:2 rd:2
[ 161.306641] disk 0, wo:0, o:1, dev:sda2
[ 161.306644] disk 1, wo:0, o:1, dev:sdb2
[ 161.306646] RAID1 conf printout:
[ 161.306648] --- wd:2 rd:2
[ 161.306651] disk 0, wo:0, o:1, dev:sda2
[ 161.306654] disk 1, wo:0, o:1, dev:sdb2
[ 161.306657] RAID1 conf printout:
[ 161.306659] --- wd:2 rd:2
[ 161.306662] disk 0, wo:0, o:1, dev:sda2
[ 161.306665] disk 1, wo:0, o:1, dev:sdb2
[ 163.985131] ext4_init_reserve_inode_table0: md0, 89377
[ 163.987026] ext4_init_reserve_inode_table2: md0, 89377, 0, 0, 4096
[ 163.988942] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: usrjquota=aquota.user,jqfmt=vfsv0,user_xattr,data=ordered,delalloc,acl
[ 188.406080] tg3 0000:04:00.0: eth0: Link is down
[ 192.143870] tg3 0000:04:00.0: eth0: Link is up at 1000 Mbps, full duplex
[ 192.144056] tg3 0000:04:00.0: eth0: Flow control is on for TX and on for RX
[ 233.063986] rule type=2, num=0
[ 233.385040] Loading iSCSI transport class v2.0-871.
[ 233.440689] iscsi: registered transport (tcp)
[ 233.478976] iscsid (7963): /proc/7963/oom_adj is deprecated, please use /proc/7963/oom_score_adj instead.
[ 240.668743] Set msys_nodify as 31743
[ 1237.952034] [1 0] Detect fake interrupts.
[ 1237.953019] QNAP: Got fake interrupts.(cnt=0)
And again after a reboot and plugging in the esata device *after* NAS was fully booted.
[~] # df -h | grep -v qpkg | grep -v grep
df: /share/external/UHCI Host Controller: Protocol error
tmpfs 64.0M 224.0k 63.8M 0% /tmp
/dev/md9 509.5M 130.7M 378.7M 26% /mnt/HDA_ROOT
[~] # mount | grep -v qpkg | grep -v grep
gphotofs on /share/external/UHCI Host Controller type fuse.gphotofs (rw,nosuid,nodev)
[~] # ls -alF /share/external/
drwxrwxr-x 29 admin administ 1024 May 25 16:30 ./
drwxrwxr-x 32 admin administ 1024 May 25 16:30 ../
drwxr-xr-x 2 admin administ 0 Dec 31 1969 UHCI Host Controller/
[~] # #done
[ 122.942491]
[ 8205.541776] [1 0] Detect fake interrupts.
[ 8205.542763] QNAP: Got fake interrupts.(cnt=96)
[ 8218.924233] [1 0] Detect fake interrupts.
[ 8218.925218] [1 0] Fake interrupts detection finished.
[ 8263.608082] [1 0] Detect fake interrupts.
[ 8263.609073] QNAP: Got fake interrupts.(cnt=0)
- pwilson
I see no hint that it is recognizing your eSATA device at all. Please submit a ticket with the QNAP Helpdesk.Davide-NYC wrote:And again after a reboot and plugging in the esata device *after* NAS was fully booted.
[~] # df -h | grep -v qpkg | grep -v grep df: /share/external/UHCI Host Controller: Protocol error df: /share/external/UHCI Host Controller: Protocol error Filesystem Size Used Available Use% Mounted on /dev/ramdisk 139.5M 111.9M 27.5M 80% / tmpfs 64.0M 224.0k 63.8M 0% /tmp tmpfs 499.7M 4.0k 499.6M 0% /dev/shm /dev/sda4 371.0M 231.7M 139.3M 62% /mnt/ext /dev/md9 509.5M 130.7M 378.7M 26% /mnt/HDA_ROOT /dev/md0 10.7T 3.8T 7.0T 35% /share/MD0_DATA [~] # mount | grep -v qpkg | grep -v grep /proc on /proc type proc (rw) none on /dev/pts type devpts (rw,gid=5,mode=620) sysfs on /sys type sysfs (rw) tmpfs on /tmp type tmpfs (rw,size=64M) tmpfs on /dev/shm type tmpfs (rw) none on /proc/bus/usb type usbfs (rw) /dev/sda4 on /mnt/ext type ext3 (rw) /dev/md9 on /mnt/HDA_ROOT type ext3 (rw,data=ordered) /dev/md0 on /share/MD0_DATA type ext4 (rw,usrjquota=aquota.user,jqfmt=vfsv0,user_xattr,data=ordered,delalloc,acl) gphotofs on /share/external/UHCI Host Controller type fuse.gphotofs (rw,nosuid,nodev) gphotofs on /share/external/UHCI Host Controller type fuse.gphotofs (rw,nosuid,nodev) [~] # ls -alF /share/external/ drwxrwxr-x 29 admin administ 1024 May 25 16:30 ./ drwxrwxr-x 32 admin administ 1024 May 25 16:30 ../ drwxr-xr-x 2 admin administ 0 Dec 31 1969 UHCI Host Controller/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sda/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdb/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdc/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdd/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sde/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdf/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdg/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdh/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdi/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdj/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdk/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdl/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdm/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdn/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdo/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdp/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdq/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdr/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sds/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdt/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdu/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdv/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdw/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdx/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdy/ drwxrwxrwx 2 admin administ 1024 Nov 17 2005 sdz/ [~] # #done
[ 63.588774] EXT3-fs (sde1): mounted filesystem with writeback data mode [ 63.748877] md: md9 stopped. [ 63.780453] md: bind<sdb1> [ 63.782739] md: bind<sdc1> [ 63.785099] md: bind<sdd1> [ 63.787460] md: bind<sde1> [ 63.789737] md: bind<sda1> [ 63.792655] bio: create slab <bio-1> at 1 [ 63.794685] md/raid1:md9: active with 5 out of 5 mirrors [ 63.796811] created bitmap (65 pages) for device md9 [ 63.805975] md9: bitmap initialized from disk: read 5/5 pages, set 0 of 132512 bits [ 63.818366] md9: detected capacity change from 0 to 542769152 [ 63.825490] md9: unknown partition table [ 64.848442] kjournald starting. Commit interval 5 seconds [ 64.898456] EXT3-fs (md9): using internal journal [ 64.900547] EXT3-fs (md9): mounted filesystem with writeback data mode [ 65.075934] md: md13 stopped. [ 65.310583] md: bind<sdd4> [ 65.312893] md: bind<sde4> [ 65.315264] md: bind<sdc4> [ 65.317598] md: bind<sda4> [ 65.319874] md: bind<sdb4> [ 65.322759] md/raid1:md13: active with 5 out of 5 mirrors [ 65.324895] created bitmap (57 pages) for device md13 [ 65.332860] md13: bitmap initialized from disk: read 4/4 pages, set 0 of 114720 bits [ 65.370803] md13: detected capacity change from 0 to 469893120 [ 65.381830] md13: unknown partition table [ 66.614940] kjournald starting. Commit interval 5 seconds [ 66.663566] EXT3-fs (md9): using internal journal [ 66.665635] EXT3-fs (md9): mounted filesystem with writeback data mode [ 85.088020] kjournald starting. Commit interval 5 seconds [ 85.139243] EXT3-fs (md9): using internal journal [ 85.141244] EXT3-fs (md9): mounted filesystem with ordered data mode [ 111.905789] kjournald starting. Commit interval 5 seconds [ 111.950344] EXT3-fs (md13): using internal journal [ 111.952367] EXT3-fs (md13): mounted filesystem with writeback data mode [ 122.546812] cryptodev: driver 0.9 loaded. [ 122.737791] generic-usb 0003:051D:0002.0001: hiddev0: USB HID v1.00 Device [American Power Conversion Back-UPS RS 700G FW:856.L1 .D USB FW:L1 ] on usb-0000:00:1d.1-1/input0 [ 122.751141] usbcore: registered new interface driver usbhid [ 122.753297] usbhid: USB HID core driver [ 122.782834] Register ICH/PCH RTC driver. [ 122.800547] iTCO_vendor_support: vendor-support=0 [ 122.831039] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07 [ 122.847054] iTCO_wdt: Found a ICH7 or ICH7R TCO device (Version=2, TCOBASE=0x0860) [ 122.853207] iTCO_wdt: initialized. heartbeat=120 sec (nowayout=0) [ 122.877246] usbcore: registered new interface driver usblp [ 122.892960] jnl: driver (lke_9.2.0 QNAP, LBD=ON) loaded at f8918000 [ 122.918439] ufsd: module license 'Commercial product' taints kernel. [ 122.920600] Disabling lock debugging due to kernel taint [ 122.942482] ufsd: driver (lke_9.2.0 QNAP, build_host("BuildServer47-1"), acl, ioctl, bdi, sd2(0), fua, bz, rsrc) loaded at f89b4000 [ 122.942485] NTFS support included [ 122.942487] Hfs+/HfsJ support included [ 122.942488] optimized: speed [ 122.942489] Build_for__QNAP_Atom_x86_k3.4.6_2014-12-15_lke_9.2.0_r245986_b56 [ 122.942491] [ 123.110046] fnotify: Load file notify kernel module. [ 124.279103] usbcore: registered new interface driver snd-usb-audio [ 124.304119] usbcore: registered new interface driver snd-usb-caiaq [ 124.338667] Linux video capture interface: v2.00 [ 124.412591] usbcore: registered new interface driver uvcvideo [ 124.414955] USB Video Class driver (1.1.1) [ 124.732326] 8021q: 802.1Q VLAN Support v1.8 [ 126.147753] tg3 0000:04:00.0: irq 44 for MSI/MSI-X [ 126.192640] tg3 0000:03:00.0: irq 45 for MSI/MSI-X [ 129.840103] tg3 0000:04:00.0: eth0: Link is up at 1000 Mbps, full duplex [ 129.840299] tg3 0000:04:00.0: eth0: Flow control is on for TX and on for RX [ 137.637292] kjournald starting. Commit interval 5 seconds [ 137.645587] EXT3-fs (md9): using internal journal [ 137.648144] EXT3-fs (md9): mounted filesystem with ordered data mode [ 144.442469] md: bind<sda2> [ 144.445834] md/raid1:md5: active with 1 out of 1 mirrors [ 144.448365] md5: detected capacity change from 0 to 542851072 [ 145.454628] md5: unknown partition table [ 147.529187] Adding 530124k swap on /dev/md5. Priority:-1 extents:1 across:530124k [ 151.540138] md: bind<sdb2> [ 151.565195] RAID1 conf printout: [ 151.565201] --- wd:1 rd:2 [ 151.565206] disk 0, wo:0, o:1, dev:sda2 [ 151.565211] disk 1, wo:1, o:1, dev:sdb2 [ 151.565669] md: recovery of RAID array md5 [ 151.568191] md: minimum _guaranteed_ speed: 5000 KB/sec/disk. [ 151.570683] md: using maximum available idle IO bandwidth (but not more than 200000 KB/sec) for recovery. [ 151.573300] md: using 128k window, over a total of 530128k. [ 153.797076] md: bind<sdc2> [ 155.939064] md: bind<sdd2> [ 156.840571] md: md0 stopped. [ 156.862034] md: md0 stopped. [ 157.116554] md: bind<sdb3> [ 157.119351] md: bind<sdc3> [ 157.122048] md: bind<sdd3> [ 157.124671] md: bind<sde3> [ 157.127238] md: bind<sda3> [ 157.130327] md/raid:md0: device sda3 operational as raid disk 0 [ 157.132506] md/raid:md0: device sde3 operational as raid disk 4 [ 157.134649] md/raid:md0: device sdd3 operational as raid disk 3 [ 157.136761] md/raid:md0: device sdc3 operational as raid disk 2 [ 157.138812] md/raid:md0: device sdb3 operational as raid disk 1 [ 157.140832] NR_STRIPES is 4096 for total 255822 ram pages [ 157.154216] md/raid:md0: allocated 84464kB [ 157.156300] md/raid:md0: raid level 5 active with 5 out of 5 devices, algorithm 2 [ 157.158297] RAID conf printout: [ 157.158299] --- level:5 rd:5 wd:5 [ 157.158304] disk 0, o:1, dev:sda3 [ 157.158307] disk 1, o:1, dev:sdb3 [ 157.158310] disk 2, o:1, dev:sdc3 [ 157.158313] disk 3, o:1, dev:sdd3 [ 157.158316] disk 4, o:1, dev:sde3 [ 157.158374] md0: detected capacity change from 0 to 11995945107456 [ 158.143639] md: bind<sde2> [ 158.273268] md0: unknown partition table [ 161.256752] md: md5: recovery done. [ 161.296898] RAID1 conf printout: [ 161.296902] --- wd:2 rd:2 [ 161.296906] disk 0, wo:0, o:1, dev:sda2 [ 161.296909] disk 1, wo:0, o:1, dev:sdb2 [ 161.306634] RAID1 conf printout: [ 161.306637] --- wd:2 rd:2 [ 161.306641] disk 0, wo:0, o:1, dev:sda2 [ 161.306644] disk 1, wo:0, o:1, dev:sdb2 [ 161.306646] RAID1 conf printout: [ 161.306648] --- wd:2 rd:2 [ 161.306651] disk 0, wo:0, o:1, dev:sda2 [ 161.306654] disk 1, wo:0, o:1, dev:sdb2 [ 161.306657] RAID1 conf printout: [ 161.306659] --- wd:2 rd:2 [ 161.306662] disk 0, wo:0, o:1, dev:sda2 [ 161.306665] disk 1, wo:0, o:1, dev:sdb2 [ 163.985131] ext4_init_reserve_inode_table0: md0, 89377 [ 163.987026] ext4_init_reserve_inode_table2: md0, 89377, 0, 0, 4096 [ 163.988942] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: usrjquota=aquota.user,jqfmt=vfsv0,user_xattr,data=ordered,delalloc,acl [ 188.406080] tg3 0000:04:00.0: eth0: Link is down [ 192.143870] tg3 0000:04:00.0: eth0: Link is up at 1000 Mbps, full duplex [ 192.144056] tg3 0000:04:00.0: eth0: Flow control is on for TX and on for RX [ 233.063986] rule type=2, num=0 [ 233.385040] Loading iSCSI transport class v2.0-871. [ 233.440689] iscsi: registered transport (tcp) [ 233.478976] iscsid (7963): /proc/7963/oom_adj is deprecated, please use /proc/7963/oom_score_adj instead. [ 240.668743] Set msys_nodify as 31743 [ 1237.952034] [1 0] Detect fake interrupts. [ 1237.953019] QNAP: Got fake interrupts.(cnt=0) [ 8205.541776] [1 0] Detect fake interrupts. [ 8205.542763] QNAP: Got fake interrupts.(cnt=96) [ 8218.924233] [1 0] Detect fake interrupts. [ 8218.925218] [1 0] Fake interrupts detection finished. [ 8263.608082] [1 0] Detect fake interrupts. [ 8263.609073] QNAP: Got fake interrupts.(cnt=0) [~] #
Patrick M. Wilson
Victoria, BC Canada
The SSH output of those last two posts were taken while the NAS was in a state such that the Drive wasn't even shown in the QTS "External Hardware" page.
By hotplugging the eSATA drive I was able to get it shown in the QTS "External Hardware" page.
Here is the output of dmesg:
And here is the output of the df and mount commands:
[/] # dmesg
[ 122.942491]
[ 9451.064931] [1 0] Detect fake interrupts.
[ 9451.065918] [1 0] Fake interrupts detection finished.
[ 9498.223756] [1 0] Detect fake interrupts.
[ 9498.224743] [1 0] Fake interrupts detection finished.
[ 9512.179553] [1 0] Detect fake interrupts.
[ 9512.180540] QNAP: Got fake interrupts.(cnt=0)
[ 9526.460111] [1 0] Detect fake interrupts.
[ 9526.461097] QNAP: Got fake interrupts.(cnt=0)
[ 9712.663151] [1 0] Detect fake interrupts.
[ 9712.664137] [1 0] Fake interrupts detection finished.
[ 9717.964024] ENABLE_WRITE_CACHE (current: disabled).
[ 9718.076142] scsi 6:0:0:0: Direct-Access H/W LARGE 0957 PQ: 0 ANSI: 3
[ 9718.081489] Check proc_name[mvSata].
[ 9718.083539] TS509 SATA TYPE is 2
[ 9718.088756] sd 6:0:0:0: [sdza] Very big device. Trying to use READ CAPACITY(16).
[ 9718.091272] sd 6:0:0:0: [sdza] 23441702912 512-byte logical blocks: (12.0 TB/10.9 TiB)
[ 9718.096038] sd 6:0:0:0: [sdza] Write Protect is off
[ 9718.098162] sd 6:0:0:0: [sdza] Mode Sense: 23 00 00 00
[ 9718.098824] Check proc_name[mvSata].
[ 9718.099110] TS509 SATA TYPE is 2
[ 9718.105034] sd 6:0:0:0: [sdza] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 9718.109991] sd 6:0:0:0: [sdza] Very big device. Trying to use READ CAPACITY(16).
[ 9718.114252] sd 6:0:0:0: Attached scsi generic sg676 type 0
[ 9718.148922] sdza: unknown partition table
[ 9718.151533] sd 6:0:0:0: [sdza] Very big device. Trying to use READ CAPACITY(16).
[ 9718.156181] sd 6:0:0:0: [sdza] Attached SCSI disk
[ 9718.269920] FAT-fs (sdza): bogus number of reserved sectors
[ 9718.272183] FAT-fs (sdza): Can't find a valid FAT filesystem
[ 9718.276229] FAT-fs (sdza): bogus number of reserved sectors
[ 9718.278379] FAT-fs (sdza): Can't find a valid FAT filesystem
[ 9718.296780] FAT-fs (sdza): bogus number of reserved sectors
[ 9718.299087] FAT-fs (sdza): Can't find a valid FAT filesystem
[ 9718.303217] FAT-fs (sdza): bogus number of reserved sectors
[ 9718.305384] FAT-fs (sdza): Can't find a valid FAT filesystem
[ 9718.323554] FAT-fs (sdza): bogus number of reserved sectors
[ 9718.325750] FAT-fs (sdza): Can't find a valid FAT filesystem
[ 9718.330243] FAT-fs (sdza): bogus number of reserved sectors
[ 9718.332320] FAT-fs (sdza): Can't find a valid FAT filesystem
[ 9718.348821] FAT-fs (sdza): bogus number of reserved sectors
[ 9718.351056] FAT-fs (sdza): Can't find a valid FAT filesystem
[ 9718.355217] FAT-fs (sdza): bogus number of reserved sectors
[ 9718.357305] FAT-fs (sdza): Can't find a valid FAT filesystem
[/] # df -h | grep -v qpkg | grep -v grep
tmpfs 64.0M 228.0k 63.8M 0% /tmp
/dev/md9 509.5M 130.8M 378.7M 26% /mnt/HDA_ROOT
[/] # mount | grep -v qpkg | grep -v grep
[/] # ls -alF /share/external/
drwxrwxr-x 30 admin administ 1024 May 25 19:08 ./
drwxr-xr-x 2 admin administ 1024 May 25 19:08 sdza/
[/] # #done
- pwilson
If you click on "USBDisk1", does it show you any useful information on the "Storage Information" tab?Davide-NYC wrote:The SSH output of those last two posts were taken while the NAS was in a state such that the Drive wasn't even shown in the QTS "External Hardware" page.
Patrick M. Wilson
Victoria, BC Canada
Presumably you mean eSATADisk1, and here is the information given:
- pwilson
What type of filesystem is supposed to be on the drives? Ext3? NTFS?Davide-NYC wrote:Presumably you mean eSATADisk1, and here is the information given:
The problem I have with providing commands for you, is that none of the information I requested you provide, has disclosed which device it is trying to mount. We could attempt to manually mount it, if we knew where it is trying to mount.
BTW "Spanning Disk" suggests it is a JBOD volume, which would be unmountable if any of the drives have failed. Did you file a ticket yet?
Patrick M. Wilson
Victoria, BC Canada
Yes, it's a CONCAT (rather than a JBOD) where the disks are concatenated sequentially to create one big disk.
(I'm considering buying a 5-Bay RAID5 esata instead of this 4-Bay)
Most recently the volume was formatted EXT4 on the QNAP.
Prior to that it was formatted it NTFS ona Win7(64bit) workstation.
I'll plug it back into the Win7 box and see if I can reformat it sucesfully (NTFS) and run a scandisk, just to check the health of the physical disks.
(what a pain)
I'm totally unqualified to diagnose this but could it be something to do with blocksize. 512kb versus 4mb maybe?
Remember that the 509 Pro firmware is 32bit only. Might that have something to do with this?
(what a pain)
On a hunch I just reformatted the drive in EXT3 and it now seems to be working.
Could some hardware compatibility have been the cause of my woes? Is my backup device a ticking time-bomb?
