Please, how repair this "[Pool 1] Storage pool used size hits threshold(90%). Free size is 0 Byte. Please expand storage pool." without formatting...
TS-870 Pro with 1 volume and 2 RAID 6 groups.
1 RAID 6 with 4 x 4GB
2 RAID 6 with 1 x 4 GB + 3 x 3 GB
Regards,
Help with Pool warning
Re: Help with Pool warning
I'm receiving this same error and need help too.
The Free Size on mine is listed as 2.0 MB and the warning says "Storage Pool free size= 2.0 MB Warning: Storage Pool used size hits threshold (80%) free size=2.0MB. Please Expand Storage Pool"
I have a QNAP TS-469L setup for RAID 6 with 4 drives of the exact same size, capacity, and manufacturer (4TB) that was listed on as a compatible drive. I also don't have anything on the drives yet as I'm still trying to get it setup.
Thanks, Rob.
Thanks, Rob.
hello
try this go to :
- storage manager
- storage pools
- on right, locate the line of your storage (my mine is "storage pool 1")
you must have a little button with pen, clic on.
- deselect option (please input the alert......) and apply.
see you later
try this go to :
- storage manager
- storage pools
see you later
TS-659 Pro II, 6x2to
VS-2008 Pro VioStor NVR, 2x1to + 4 CAM VIVOTEK
+ onduleur bien entendu.
TS-509P décédé
TS-509P décédé
this isn't a solution!pdm wrote:hello
try this go to :
- storage manager
- storage pools
see you later
why it's giving that error?
I doubt that it's a bug
