Came home and found we had a power outage. Qnap had flashing red light. I restarted the device and status is still flashing red. The 4 drive lights are all steady green. Qfinder says ".. has not been configured yet. Would you like to run the setup wizard to set up the server now?"
The box has 4x2TB drives configured as 1 vol. It runs as a NAS not a server and is my media library storage.
If I run the wizard, will I lose all current data? This is not catastrophic but would be downright annoying. I would need to resource and rebuild the movie, TV and music libraries, many hours/days of work with lots of loss along the way.
Please, not lectures about backups, I was naughty I know, but to date never had a problem like this, even through some pretty nasty power and network issues.
TS 412 Failed after Power Outage
Access Failure After Power Outage
Came home and found we had a power outage. Qnap had a flashing red light. I restarted the device and status is still flashing red. The 4 drive lights are all steady green. Qfinder says ".. has not been configured yet. Would you like to run the setup wizard to set up the server now?"
PS: I posted this in another stream before I found this one. Hope this doesn't cause problems.
- schumaku
Re: TS 412 Failed after Power Outage
Fully agree, issues like these should never happen. You are kindly asked to contact QNAP Customer Service http://helpdesk.qnap.com/ for assistance to create the awareness required.
Thank you, I have submitted a support ticket as suggested.
Thanks guys, all is well, or well enough. QNAP did help with some live terminal stuff. It took many weeks, but I managed to save all the data, which is now spread across a bunch of USB attached drives. My current task is deciding what configuration I will use before I start to transfer the files back. It is a long slow process.
