Hi All,
I have a qnap-870-rp (Firmware 4.05) and have just installed a REXP-1600U to increase the capacity.
The setup on the main unit is one raid 6 volume across the 8 x 4tb disks.
There is no storage pool, as I think this was not an option with the firmware version at the time.
What I would like to do is have one large volume across both units, due to the curent setup it doesn't give me the option to expand the volume (which I gather would not be the case if it was on a storage pool).
SO...my plan is as follows
1. Create a new storage pool with the 16 x 4tb disks in the expansion unit.
2. Create a volume on that with a new share.
3. Copy the data from the original volume to the new one.
4. Delete the old volume and shares
5. add the disks from the old volume to the new storage pool
6. Expand the new volume
Does that sound like it would work, are the any pitfalls to doing this if I delete the only volume on the main unit etc?
Any thoughts much appreciated.
Expansion Queries
- Don
Re: Expansion Queries
I would open a ticket with QNAP support and run this by them. Also step 0 should be to create a backup of your data.
Sent from my iPad using Tapatalk HD
Thanks, good point have logged a case with support to get their thoughts.
Not sure I can back it up due to the size, it's not prduction data, it's essentially stuff that has been previoulsy archived to tape and then restored for reference so worse case scenario it can be re-restored.
- storageman
Sounds like this would work.
Obviously, you can't add the disks per se to the new RAID group on REXP, you would create new RAID group on TS870 header and add this to be pool once you've deleted/recreated original RG.
thanks for the repy storageman, not quite sure I follow what you mean though?
- storageman
Really? You create separate RAID groups, one on expansion and one on head and add to the pool
http://www.qnap.com/i/en/qts4_smb/con_s ... e=1&hf=old
http://www.qnap.com/images/products/App ... nap_01.png
TS870 RG 2
------------------------------------------> STORAGE POOL 1
REXP1600 RG 1
TS870 RG 2
REXP1600 RG 1
Yes I understand the concepts of how it will look/work once in place.
Perhaps I mis-interpreted your reply but it reads like you're suggesting deleting the original volume first which is not what I outlined in my original post?
- storageman
No just as you stated but build rg 1 on expansion, then delete orig rg, recreate as rg 2 and add to pool
