i have followed all the steps in order to setup SSD caching on my NAS. Drive (Samsung Evo 500GB) - NAS sees drive and i can enable SSD Caching when select the "Cache Acceleration" as per attachment one. I then proceed to the volumes tab and i click on "Actions" -> "cache Setting". i can select SSD Caching but then i get the following error message.
A: What does this mean
B: How do i resolve this?
C: will i need to remove the Volume and re-create it?
D: Is there a command i can run to solve this without loosing all my data?
Thanks for the help...
TS-870 Pro SSD Volume cache Error
- pwilson
Re: TS-870 Pro SSD Volume cache Error
Are you following QNAP Tutorial: QNAP Turbo NAS with SSD Cache?robbied wrote:Hello,
(I have no experience with SDD Cache personally, I simply want to ensure that you are aware of this document).
Patrick M. Wilson
Victoria, BC Canada
Hello. Yes I have seen and followed this document. However I don't get to assign a volume I. Thhe cache acceleration menu. I am also running 4.1 firmware if this helps anyone.
- storageman
I assume this is not a legacy volume, e.g created before storage pools.
Can you replicate issue by deleting cache and recreating problem?
I would contact Qnap support for advice then.
Hello no this is brand new NAS. i created the pool and volume and then copied all the data over and now trying to enable SDD Caching.
- schumaku
What shows up when open [Cache Settings] on the Cache Acceleration control page?
see the attached image in original post.
- schumaku
Hm, that's the creation of the cache. Here what I expect to see:
