I also see there is a model TS-653 Pro, which is very similar to the TS-651. But there is confusing/conflicting documentation on what is supported for them (and if it will change over time).
A model comparison shows that the TS-651 is a Home/SOHO, while the TS-653 Pro is a SMB.
BUT the user manual page for 4.1 shows that BOTH are given the SMB version. Why the discrepency? Which is correct?
Requirements:
- RAID 1+ for all data. Having redundancy is key.
- Support for RAID 5 and RAID 6
- Two "volumes" - 1 smaller volume (~300GB) for encrypted sensitive data, and 1 larger (~6TB+) for everything else.
- The documentation indicates that Volumes are strictly entire disks or raid sets - correct? So I would need 2 raid sets. At RAID 1 for both, that means 4 drives. At RAID 5 for both, that means 6 drives - correct?
- The ability to grow volumes by adding more (or larger) drives.
- Access of the encrypted volume from a linux host as a mount.
- Ideally - support for SSD's. Because I need only 300GB of encrypted storage, putting that on a pair of SSD's with RAID 1 would be perfect. It seems that QNAP doesn't support RAID TRIM.
Are these points possible on both models? And a reasonable design?
Thanks in advance!
