I was hoping I could get some advice on the least painful path to my goal of swapping a bad drive and upgrading my array on my QNAP TS-459 Pro.
The unit originally had four 1.5TB drives in a RAID5 + hot spare configuration. One drive failed a few months back and I swapped it for a 3TB NAS rated drive with the idea being that I would eventually swap out all the others to take advantage of the extra capacity and reliability.
Yesterday a second drive failed, the hot spare kicked into action and the array rebuilt.
My goal now is to replace the one failed drive and the two remaining old 1.5TB drives with matching 3TB NAS drives and also migrate to a four drive RAID 6 array rather than the RAID 5 +hot spare.
If I just replace the bad drive first, will that automatically make it the hot spare? Or will I be prompted as to how I want to use the new drive and I can migrate to RAID 6 at that time, then after the migration swap the remaining lower capacity drives one at a time to expand the array?
Thanks!
TS-459 Pro
QTS 4.0.3
2x Seagate 1.5TB ST31500341AS (old drives)
2x Seagate 3TB NAS ST3000VN000 (new drives)
Migrate from RAID5 + hot spare to RAID6 after degraded
- jds580s
Model: TVS-1282-i5-16G
[list]
[*]Firmware: QTS 4.5.3.1652 build 20210428
[*]Network: 10GbE ASUS XG-C100C card, MTU 9k
[*]RAID 1: [System] 2x WD Blue M.2 SSD 250GB
[*]RAID 6: [DATA] 5x HGST HDN728080ALE604 8TB
[list]
[*] Qtier RAID 1: 2x Samsung SSD 850 EVO 500GB + 2x Samsung SSD 860 EVO 500GB
[*] Cache RAID 1: 2x Samsung SSD 960 EVO 500GB NVMe M.2 in two NGFF PCIe 3.0 x4 adapter cards[/list][/list]
Model: TS-459 Pro
[list]
[*]Firmware: QTS 4.2.6 build 20210327
[*]RAID 6: 2x HGST HDN724030ALE640 3TB, x2 Seagate ST3000VN000 3TB
[*]External: 4TB HGST eSATA Drive, UPS
[*]Network: 1 Gbps, MTU 1500[/list]
[/color]
- doktornotor
Re: Migrate from RAID5 + hot spare to RAID6 after degraded
Which information on RAID migration are you missing in the fine manual?
http://docs.qnap.com/nas/4.0/Home/en/ra ... gement.htm
I'm gone from this forum till QNAP stop wasting volunteers' time. Get help from QNAP helpdesk instead.
Warning: offensive signature and materials damaging QNAP reputation follow:
QNAP's FW security issues
QNAP's hardware compatibility list madness
QNAP's new logo competition
Dear QNAP, kindly fire your clueless incompetent forum "admin" And while at it, don't forget the webmaster!
- schumaku
One of the keys - please don't forget:
Then complete the RAID if it's still degraded by swapping the next broken HDD. Once successfully rebuild - strictly follow the guided RAID migration process. In the slots where you have the new HDD - just remove it, and plug the same HDD back.Note: A hot spare drive must be removed from the disk volume before executing the following action:
• Online RAID capacity expansion
• Online RAID level migration
• Adding a hard drive member to a RAID 5, RAID 6 or RAID 10 volume
- jds580s
Thanks so much! The migration is in progress, and I appreciate the tip on removing and re-plugging the drives that are already new for the expansion.
[list]
[list]
Model: TS-459 Pro
[list]
[/color]
