The most significative error is "The file system is not clean", it was already displayed even before of the story...
I need to access to my file in the next 24 hours, and it started about 1 hour ago and it's still at 0%. Any suggestion?
"Number","Type","Date","Time","Users","Source IP","Computer name","Content"
"578","Information","2014-09-02","21:16:55","System","192.168.0.3","localhost","[HDD SMART] HDD 3 Rapid Test started."
"577","Warning","2014-09-02","21:16:45","System","192.168.0.3","localhost","[HDD SMART] HDD 3 Rapid Test was cancelled."
"576","Information","2014-09-02","21:10:29","System","192.168.0.3","localhost","[HDD SMART] HDD 3 Rapid Test started."
"575","Information","2014-09-02","21:05:20","System","127.0.0.1","localhost","[Mirror Disk Volume: Drive 1 2] Start resyncing."
"574","Warning","2014-09-02","21:04:40","System","127.0.0.1","localhost","[Mirror Disk Volume: Drive 1 2] The file system is not clean. It is suggested that you go to [Storage Manager] to run "Check File System"."
"573","Information","2014-09-02","21:03:26","System","127.0.0.1","localhost","[Media Library] Media Library Server started."
"572","Information","2014-09-02","21:01:54","System","127.0.0.1","localhost","System started."
"571","Information","2014-09-02","20:57:16","System","127.0.0.1","localhost","System was shut down on Tue Sep 2 20:57:16 CEST 2014."
"570","Information","2014-09-02","20:53:39","admin","192.168.0.3","---","[Power Management] System restarting now."
"569","Error","2014-09-02","20:50:56","System","127.0.0.1","localhost","[HDD SMART] HDD 4 Rapid Test result: Completed: read failure."
"568","Information","2014-09-02","20:50:43","System","192.168.0.3","localhost","[HDD SMART] HDD 4 Rapid Test started."
"567","Error","2014-09-02","20:50:22","System","127.0.0.1","localhost","[HDD SMART] HDD 3 Rapid Test result: Completed: read failure."
"566","Information","2014-09-02","20:50:00","System","192.168.0.3","localhost","[HDD SMART] HDD 3 Rapid Test started."
"565","Information","2014-09-02","20:49:13","System","127.0.0.1","localhost","[HDD SMART] HDD 1 Rapid Test result: Completed without error(s)."
"564","Information","2014-09-02","20:47:09","System","192.168.0.3","localhost","[HDD SMART] HDD 1 Rapid Test started."
"563","Error","2014-09-02","20:46:17","System","127.0.0.1","localhost","[HDD SMART] HDD 3 Rapid Test result: Completed: read failure."
"562","Information","2014-09-02","20:45:56","System","192.168.0.3","localhost","[HDD SMART] HDD 3 Rapid Test started."
"561","Information","2014-09-02","08:31:48","System","127.0.0.1","localhost","[Mirror Disk Volume: Drive 3 4] Start examination."
"560","Information","2014-09-01","20:01:41","System","127.0.0.1","localhost","LAN 1 link is Up."
"559","Information","2014-09-01","19:59:04","System","127.0.0.1","localhost","LAN 2 link is Down."
"558","Information","2014-09-01","11:56:31","System","127.0.0.1","localhost","[Mirror Disk Volume: Drive 1 2] Start resyncing."
"557","Warning","2014-09-01","11:56:11","System","127.0.0.1","localhost","[Mirror Disk Volume: Drive 3 4] The file system is not clean. It is suggested that you go to [Storage Manager] to run "Check File System"."
"556","Warning","2014-09-01","11:56:04","System","127.0.0.1","localhost","[Mirror Disk Volume: Drive 1 2] The file system is not clean. It is suggested that you go to [Storage Manager] to run "Check File System"."
"555","Information","2014-09-01","11:54:50","System","127.0.0.1","localhost","[Media Library] Media Library Server started."
"554","Information","2014-09-01","11:53:18","System","127.0.0.1","localhost","System started."
"553","Information","2014-09-01","11:45:54","System","127.0.0.1","localhost","System was shut down on Mon Sep 1 11:45:54 CEST 2014."
"552","Information","2014-08-30","18:21:08","System","127.0.0.1","localhost","[Mirror Disk Volume: Drive 1 2] Start resyncing."
"551","Warning","2014-08-30","18:20:38","System","127.0.0.1","localhost","[Mirror Disk Volume: Drive 1 2] The file system is not clean. It is suggested that you go to [Storage Manager] to run "Check File System"."
"550","Information","2014-08-30","18:19:36","System","127.0.0.1","localhost","[Media Library] Media Library Server started."
"549","Information","2014-08-30","18:18:11","System","127.0.0.1","localhost","System started."
"548","Warning","2014-08-30","18:18:10","System","127.0.0.1","localhost","The system was not shut down properly last time."
"547","Information","2014-08-30","18:14:13","System","127.0.0.1","localhost","System started."
"546","Warning","2014-08-30","18:14:12","System","127.0.0.1","localhost","The system was not shut down properly last time."
"545","Warning","2014-08-30","17:29:31","System","127.0.0.1","localhost","[Mirror Disk Volume: Drive 3 4] The file system is not clean. It is suggested that you go to [Storage Manager] to run "Check File System"."
"544","Warning","2014-08-30","17:29:26","System","127.0.0.1","localhost","[Mirror Disk Volume: Drive 1 2] The file system is not clean. It is suggested that you go to [Storage Manager] to run "Check File System"."
"543","Information","2014-08-30","17:28:24","System","127.0.0.1","localhost","[Media Library] Media Library Server started."
"542","Information","2014-08-30","17:27:00","System","127.0.0.1","localhost","System started."
"541","Information","2014-08-30","17:14:11","System","127.0.0.1","localhost","System was shut down on Sat Aug 30 17:14:11 CEST 2014."
"540","Information","2014-08-30","17:10:20","admin","192.168.0.11","---","[Power Management] System restarting now."
"539","Information","2014-08-30","17:09:11","admin","192.168.0.11","---","[App Center] Video Station disabled."
"538","Information","2014-08-30","17:08:45","admin","192.168.0.11","---","[Multimedia Station] Multimedia Station disabled."
"537","Information","2014-08-30","17:08:44","admin","192.168.0.11","---","[File Station] Standalone Web File Station disabled."
"536","Information","2014-08-30","16:59:42","admin","192.168.0.11","---","[iTunes Service] iTunes service disabled."
"535","Information","2014-08-29","21:59:34","System","127.0.0.1","localhost","LAN 2 link is Up."
"534","Information","2014-08-29","21:59:27","System","127.0.0.1","localhost","LAN 2 link is Down."
