Hi all,
i get the following error, when adding a second disk:
"ERR_FAIL_CREATE_POOL"
Device: TS-251
Firmware: 4.1.1
What i did before:
- Installed 1st HDD as single drive (no raid, no JBOD)
- Copied data to it, installed some applications etc. So far so good, everything is fine.
- Finally i wanted to add a 2nd disk (same model, same size. Again as single drive, no raid or JBOD) and got above error message.
Where is my mistake?
Does someone faced this issue already?
Thanks in advance and best regards
Adding second disk: ERR_FAIL_CREATE_POOL
Re: Adding second disk: ERR_FAIL_CREATE_POOL
Well...strange...
I have installed just now the Qfix for Shellshock and tried again to initialize my 2nd HDD.
Guess what - it worked...
Are there any logs, that will give some details?
This is really strange...
