- Windows 7/8
- TS-809U-RP (firmware version: 3.8.4 Build 20130816)
- Single Port
- RAID 5
- 8 Drives
- Crucial
- M500 - ATA M4-CT512M4SSD2 000F
- Do not know the firmware of the drives.
[/url]
I want to preemptively fail the drive so I can remove it and replace it with a Crucial M500 960GB (CT960M500SSD1) - the 512GB models aren't available any longer. So my question is do I just use the Online RAID Capacity Expansion Procedure to fail the drive, then replace it? Then once it's in place, should I expand the capacity, or would I loose the hot spare functionality if I put a larger drive in place then expand it (should I just let the QNAP device partition it as a 512GB drive?).
My other question was theoretical... what if I didn't follow the capacity expansion procedure, and just pulled drive 1 with the RAID array running, and put the new disk in (hot swapped it)?
