TS-509 unstable network performance
I'm using a TS-509 in my mac environment for multimedia storage. The TS-509 is wired with two Ethernet cables into a Linksys Gigabit switch (EG008W). The network tab on the QNAP shows that it's connected at a speed of 1000MBPS. While I'm transferring 700GB from one disk to another on the same NAS I've noticed varying transfer speeds. The highest speed I get is about 50MB/s (mainly the first 15 minutes of a transfer) versus 345Kb/s at the end. But the speed varies during the whole transfer of the data. It's almost a wave pattern...slow...speed is pickup...and slowing down again. The speed varies, after the initial high speed of 15 minutes, between 1.0 MB/s and 27.0 MB/s. See below the graphs:
Anybody an idea how to solve this? (BTW: Twonky, TM and all other applications are switched off)
My network is setup with port trunking with the option set on Active Backup(Fail Over). The speed doesn't change if I change the port trunking option to Balance-rr. So in the end I left it to Active Backup. I start to wonder if Port Trunking actually works on the linksys switch? Anybody knows?
Many thanks for any help.
- Easy as a breeze
Re: TS-509 unstable network performance
you tell us that you transfer a file from 1 disk on the nas to another...
How do you copy the file? the only 2 correct ways are
- use filemaneger on the nas
- ssh into the box and move the file
any other way would pull the file to your desktop and then transfer it back to the nas... (while the above 2 options moves the file locally without transferring it over the network)
you have to tell us more, about your setup...
filesystem used (ext3 or ext4)
network filesystem used (afp, smb, nfs)
client setup (wifi or cabled)
mtu size (1500 or bigger)
client OS (OSX, Linux or Windows)
etc
There are a lot of parameters influencing the speed of the nas (and the graphs on the nas do not help they are only to indicate not to measure)
all the balance methods only help when there are multiple hosts writing to the nas... it does nothing for single host transfers to the nas...
etc
Three things in life are certain: Death, taxes & lost data. Guess which has occurred.
@sodium,
First thanks for the reply; it's clear you know your way around this.
You are right about copying files between disk on the NAS. I did it in a stupid way using Forklift a mac app...so indeed all the files are being transferred over the network. Was focussed on getting the NAS quickly in the network using the default settings not even touching the web file manager. The shop where I bought the QNAP installed the disks and formatted them into ext4 which as you said, in an earlier post, isn't most stable so I've reformatted all disks back to ext3.
So to answer your questions;
-filesystem: ext3
-network filesystem: afp
-client setup: wired macpro, two wired media streamers (popcorn c200), another NAS Buffalo Terastation, macbooks (wifi)
-MTU size 1500
-client os: OSX, Linux on Buffalo NAS, not sure about OS on popcorn but I suppose Linux as well
I was copying the files from one disk on the QNAP via macpro to another disk on QNAP.
Even though it wasn't the smartest way of moving files across the QNAP it's still strange that the network performance is so varying. And as the graphs showed also the CPU usage was going up and down in the same rhythm as the transfer speed. How to solve?
About balancing. Your point is understood but would it make sense to set it up as balanced-rr if I would use multiple hosts? Like using multiple macbooks, macpro and streamers etc?
-filesystem: ext3
-MTU size 1500
- Easy as a breeze
As you may have noticed, this is not the fastest wayAngelo wrote:[...]
your settings are all oke.
are you sure the rebuild of your disks is complete (home >> Disk mangement >> RAID management) Look at the Status it should say: Ready if you see anything else its still rebuilding the RAID set and that is the reason the systems is slow...Angelo wrote:Even though it wasn't the smartest way of moving files across the QNAP it's still strange that the network performance is so varying. And as the graphs showed also the CPU usage was going up and down in the same rhythm as the transfer speed. How to solve?
if you have a status ready then we have a difficult one... (and an even harder on to prove) but most likely it's tech stuff
my advise would be :
install the Optware-ipkg (at Home >> Applications >> QPKG plugins)
install the dstat (at the command prompt
ipkg install dstat
start
dstat -a
usr sys idl wai hiq siq| read writ| recv send| in out | int csw
2 2 95 2 0 0| 220k 414k| 0 0 | 3B 8B| 229 285
5 7 86 2 0 0| 33k 96k| 538B 1428B| 0 0 | 300 794
1 1 98 0 0 0| 0 0 |1289B 3415B| 0 0 | 91 246
1 1 98 0 0 0| 0 0 | 156B 428B| 0 0 | 68 98
0 0 100 0 0 0| 0 220k| 140B 2781B| 0 0 | 119 147
0 0 100 0 0 0| 0 0 | 280B 680B| 0 0 | 83 106
1 0 99 0 0 0| 0 80k| 140B 476B| 0 0 | 96 126
0 2 98 0 0 0| 0 0 | 140B 476B| 0 0 | 91 251
1 0 99 0 0 0| 0 0 | 70B 358B| 0 0 | 75 105
0 0 100 0 0 0| 0 0 | 140B 476B| 0 0 | 74 107
1 1 98 0 0 0| 0 0 | 140B 476B| 0 0 | 82 110
0 0 100 0 0 0| 12k 64k| 140B 476B| 0 0 | 102 130
1 1 98 0 0 0| 0 0 | 140B 492B| 0 0 | 102 253
0 1 99 0 0 0| 0 0 | 70B 358B| 0 0 | 68 100
0 0 100 0 0 0| 0 0 | 140B 476B| 0 0 | 86 111
1 0 99 0 0 0| 0 0 | 140B 476B| 0 0 | 75 104
3 6 89 2 0 0| 18k 24k| 140B 476B| 0 0 | 201 426
2 3 94 1 0 0| 15k 72k|1288B 3415B| 0 0 | 197 624
what you see here is my nas while nothing is going on
then the most imprtand columns are wai (waiting on I/O) and off course read (Data read) write (Data Write)
keep this running for a while and look at the numbers while doing things on the NAS... then you will probably prove that when the performance is degraded the system is writing data to the disks (and calculating the RAID) and this is greatly determined by the RAID level and speed of your disks (and the amount of cache on them)
I've never been fond of balance-rr myself - yes, it does allow a single stream to go faster than one link, but the cost is reordered packets that will trigger additional TCP ACK segments, and if there is enough reordering, spurious 'fast' retransmissions. Always keep in mind that the speed culprit is not the network -- it's always the disk(s)... and my performance tests did show that all multiple nick modes are only helpful when the number of nodes > 20 (accessing the NAS)Angelo wrote:About balancing. Your point is understood but would it make sense to set it up as balanced-rr if I would use multiple hosts? Like using multiple macbooks, macpro and streamers etc?
my 2 cents
Installed Optware and then dstat but when I try to run it it gives me;
What can I do about this?
[/etc/init.d] # dstat -a
Terminal width too small, trimming output.
- Easy as a breeze
make your terminal window biggerAngelo wrote:Installed Optware and then dstat but when I try to run it it gives me;What can I do about this?Code: Select all
[/etc/init.d] # dstat -a Terminal width too small, trimming output.
eg by pressing the green button or by pressing the "command" key and - (same as View + Smaller do several times to make the font smaller)
HTH
Duh!
Of course I tried that...it doesn't matter if I make terminal 200-500 characters width it's till too small???
- Easy as a breeze
ok ok
but does it produce any output? and if can you copy it here (please enclose output in code blocks -- next to the Quote)
Pfff..really annoying...no it doesn't produce any output. I just see an empty terminal screen with a cursor crawling downwards
Maybe there's something wrong with dstat look at this:
It looks like dstat has somehow defined his own terminal width to zero. Any ideas? Reinstall or use different version?
[~] # dstat --version
Dstat 0.7.0
Written by Dag Wieers <dag@wieers.com>
Homepage at http://dag.wieers.com/home-made/dstat/
Platform posix/linux2
Kernel 2.6.30.6
Python 2.5.5 (r255:77872, Feb 17 2010, 04:07:04)
[GCC 4.2.1]
Terminal type: linux (color support)
Terminal size: 0 lines, 0 columns
Processors: 1
Pagesize: 4096
Clock ticks per secs: 100
internal:
aio,
cpu,
cpu24,
disk,
disk24,
disk24old,
epoch,
fs,
int,
int24,
io,
ipc,
load,
lock,
mem,
net,
page,
page24,
proc,
raw,
socket,
swap,
swapold,
sys,
tcp,
time,
udp,
unix,
vm
- Easy as a breeze
I have the same version...
What is your TERM value
it should say
rxvt
[~] # echo $TERM
rxvt
it says...linux
[/etc] # echo $TERM
linux
- Easy as a breeze
start the OSX terminal program (command + Spacebar >> type Terminal [enter])
In the Command menu click on Terminal >> and choose Preferences
press the plus sign on the left and create a new settings window (default this is called "new settings")
press the default button (making this the new default)
click on advanced tab
click on declare terminal as: rxvt
close the preferences pane
click on shell >> new window >> new settings (or whatever you called it)
connect to the NAS
try dstat again
connect to the NAS
try dstat again
Don't understand it. I've done exactly as you said...changed the default terminal setting.
Do I need to restart my mac for this?
Used it but again it shows up as linux. And still it gives me Code: Select all
[~] # echo $TERM
linux
- Easy as a breeze
then there must be a local (*1) file overriding the environment variable:
start the terminal as you normally do
type (before you connect to the NAS)
then connect tot the NAS
(*1) other way to tackle this would be to create a new user on your system and ssh from that user to the NAS (but there is still a possibility the change happens globally on your system so option 1 is safer)
$ export TERM=rxvt
