Hi All,
I need your expert advice. I'm getting this error when ever I'm creating a VM in Virtualization Station.
I have installed Virtualizatio Station without any error. And I'm creating the VM as instructed.
Just want to know it I'm doing it correctly?
If I create the VM without specifying an ISO image the VM will be created properly. Then from there I'll place an ISO then start the VM to proceed with the OS installation.
I seems there is something to do with the CD Image/ISO. Just to note the ISO is valid as I used it with my other vSphere servers.
Thank you in advance for the help.
Kind regards,
Garry
Creating new VM in Virtualization Station
Re: Creating new VM in Virtualization Station
Just faced the same error, my iso image had spaces and special characters in its name, once renamed, the above error is gone, hope it helps
Regards
Muhieddine
Regards
Muhieddine
