Apache + perl + cgi-bin
Post your questions about Web Server usage and Apache + PHP + MySQL/SQLite web applications.
mr_density
Post by mr_density »
I installed perl (with ipkg) on my qnap 219p but now I also want to enable *.pl scripts to run in my cgi-bin dir in the webserver(/share/Qweb/cgi-bin). At first the browser only showed the perl code so I had to enable perl in the apache.conf file. I added the following to my apache.conf to enable perl :
AddHandler cgi-script .cgi .pl
<Directory />
  Options FollowSymLinks +ExecCGI
  AllowOverride None
</Directory>
But when I open the browser now and enter the url to my perl script I get : You don't have permission to access /cgi-bin/tm/co_login.pl on this server.
Any ideas are welcome how to solve this!
takashige
Re: Apache + perl + cgi-bin
Post by takashige »
I’m trying to do same thing on TS-659 pro, and have same problem as above.
The permission value of perl script is 755.
takashige
Post by takashige »
oops, it’s just that I set the “Options” directive to wrong directory. Sorry.
mr_density
Can you post your apache.conf?
I tried setting the directive but cant get it working. While I can execute a perl script on my server via putty so I know perl is working..
Hope someone can help?!
mr_density
Is it possible that there is no mod_perl installed in apache?
Is this a requirement for perl to work with apache?
daryanx
Post by daryanx »
Mod-perl for apache.... I am struggling with this as well. Does anybody know if there has been a guide written for this?
mmuessig
Post by mmuessig »
I have the same problems, getting perl scripts run on built-in apache on qnap ts439 pro II...
IMHO, the build-in apache comes with NO perl support!
you can check your compiled in modules with the command /usr/local/apache/bin/apache -l
i was wondering if one has solved this yet?
isn't it possible to run perl scripts as cgi-scripts and with the help of perl-cgi (which you can install as ipkg package)?
Anyone out there who has a running apache on qnap with perl support?
thanks
Return to “Web Server & Applications (Apache + PHP + MySQL / SQLite)”
