Hello All,
I work drupal 7 and i have learn on my work for Drush working.
Now what i will on my QNAP install drush
i having install drush /share/Web/drupal/drush <-- unpack to /Bin/ and reboot
than is delete drush folder on /bin/
What is problem or i wrong folder on /Bin/
Where can i drush on user/bin of bin working drush for drupal and thanks
Drupal Drush 7
Re: Drupal Drush 7
i have now fix
/share/Web/drupal/drush on /usr/bin
and i test drush say command not found
drupal test drush say command not found
i back search /usr/bin there yes folder drush good not delete and command not found
Re: Drupal Drush 7
Know all not this Drupal Drush on QNAP?
- schumaku
Re: Drupal Drush 7
Knowing nothing at all about Drush - quickly reading https://github.com/drush-ops/drush shows it's about running a binary. Unless you have a binary built for an ARM processor with a library environment matching to the QNAP NAS - i.e. a binary build for an Intel processor can't be run here.
Re: Drupal Drush 7
My Qnap 219II is certainly Arm processor.
Hence at work have qnap nas but no other brand that have Intel anyway thanks for explanation, I now know really sorry can not work then just turn super thanks Drupal drush
- schumaku
Re: Drupal Drush 7
The OP has a DS1010+ which is certainly Intel based - no idea what you want to tell us here.bassie86 wrote:See here Synology .... that wel.
Re: Drupal Drush 7
Thanks i know now that intel can drush and not for arm .
