[ CronWeb ] [ 2.00 ] [ Manage & Edit CronTab ]
- QNAP_Stephane
Source : https://github.com/fisherinnovation/CronWeb
Download :
http://www.positiv-it.fr/QNAP/APP/CronWeb_1.00.qpkg.zip
http://www.positiv-it.fr/QNAP/APP/CronWeb_2.00.qpkg.zip
Note :
Edit & Create ConJob on your Qnap NAS
WebUi on port 10000
Warning, all modification of the current activ job, may create bad behavior on your NAS
Last edited by QNAP_Stephane on Tue Jun 09, 2015 9:52 pm, edited 2 times in total.
- Briain
Re: [ CronWeb ] [ 1.00 ] [ Manage & Edit ConTab ]
Cool; that sounds like loads of fun (and indeed, seriously useful)! I'm really looking forwards to experimenting with it (even though I'm already a self-confessed SSH enabled crontab tweaker).QNAP_Stephane wrote:...Edit & Create ConJob on your Qnap NAS
WebUi on port 10000
Don't worry, many of us rather enjoy a bit of user-induced bad behaviour on our NAS units; it gives them 'character'!QNAP_Stephane wrote:...Warning, all modification of the current activ job, may create bad behavior on your NAS
Thank you very much for posting the above information!!
All the best,
Bri
TS-119, 1 X Seagate ~~ TS-219, 2 X Seagate (R1) ~~ TS-453A, 2 X 3 TB WD Red (R1) ~~ TS-659, 5 X 1 TB Hitachi Enterprise (R6)
APC Smart-UPS 750
APC Smart-UPS 750
- QNAP_Stephane
Re: [ CronWeb ] [ 1.00 ] [ Manage & Edit CronTab ]
thanks Briain,
i have plently other Apps that i published on Cachem Forum (France), just need some time to publish it here.
http://forum.cachem.fr/viewforum.php?f= ... 283c14afef
better warn users than cure
Stéphane,
Stéphane,
- Been there, done that
Thank you Stéphane, excellent repository!
For pydio, look here: http://forum.qnap.com/viewtopic.php?f=156&t=109360
Qnap TS-253Pro 16Gb RAM - Single Storage Pool: 2 WRed 4TB (RAID 1)
Qnap TS-453A 16Gb RAM - Single Storage Pool: 4 WRed 4TB (RAID 5)
- QNAP_Stephane
thanks,
Pydio will be updated and published here
i will do it as soon as possible
One OT question: how to install qpkg from terminal? Actually I want to download the packages with download station and then install them via terminal.
Thanks,
giopas
Thanks,
giopas
Thanks (over again) Philippe, that was the missing part I needed!
...Et merci à tous les développeurs français (ou en tout cas francophones)!
giopas
giopas
- QNAP_Stephane
@ Philippe
thanks for your welcome, indeed i lack of time to be everywhere, but free to you to publish it elsewhere
I am from Qnap Support french team and presales.. I will try to support in the best way my applications
I was well known develloper for another NAS brand (starting with T....) with more 700 apps developped and maintained.
cheers,
Stéphane,
cheers,
Stéphane,
Good job,
it looks fine. But I'd like to ask if can I set login with admin account in app?
Kaudik
Kaudik
- QNAP_Stephane
I think you can do it by editing the apache.conf file within the qpkg, with a simple apache credential request.kaudik wrote:Good job,
Kaudik
http://httpd.apache.org/docs/2.2/en/howto/auth.html
but not tested...
I made it tun on a custom port to allow NAT routing easily, you can also simply disable application once you set your cronjob...
- QNAP_Stephane
Thanks Philippe for this tip
father_mande wrote:Hi,
Just add a .htaccess in the base (folder) of application server you use (generally where are the index.html, index.php, etc.
limit access right to r only (all because read by Apache user : httpdusr) except admin
this can work until QNAP change the password encoding ...
here after a short working example ... but you can add more rules, control (SSL,etc.), or limits, etc. ...
adapt it to your own index, etc.Philippe.Code: Select all
#SSLOptions +StrictRequire #SSLRequireSSL Options -Indexes AuthName "Community-QPKG-Web: Admin Restricted Access" AuthType Basic AuthUserFile /mnt/HDA_ROOT/.config/shadow AuthGroupFile /dev/null DirectoryIndex index.html <limit GET POST> require user admin Options +ExecCGI </Limit>
Thank you, it works
- QNAP_Stephane
Re: [ CronWeb ] [ 2.00 ] [ Manage & Edit CronTab ]
Updated 2.00 fixing issue cronjob non persistent
Yes, some people might call you "well known developer". To me, you are a legend, hero, [put nice word for a hard working dev here]!QNAP_Stephane wrote:I was well known develloper for another NAS brand (starting with T....) with more 700 apps developped and maintained.
Qoolbox, so good to talk to you again. I must have been blind the last couple of weeks because I have missed that you started to post you modules here. You have answered so many of my module requests back in our old T... time at the other forum. Great to see you are now with Qnap.
Keep up the great work and have a good weekend,
tobilux
QNAP TS-451 Firmware 4.2.0 b0925
4x WD RED 4TB (RAID5)
- QNAP_Stephane
Thanks Tobi, Nice to see you again in Qnap World
I will try to do my best to support community as i did for Thecus in Past, but i admit the Qnap Librarie is already large compared the Thecus one where all was to do
