@tmt
I've created a new shared directory called 'share' ( I wasn't feeling very creative
). The new share is available to mount according to the output from showmount -e:
Export list for qnap:
/share
/Qweb
/Qusb
/Qrecordings
/Qmultimedia
/Qdownload
/Public
/Network Recycle Bin 1
@schumaku
I just updated to the latest firmware, 3.4.2 Build0331, and the problem remains.
Here's my dmesg output:
TB/1.81 TiB)
sd 0:0:0:0: [sda] 0-byte physical blocks
Check proc_name[mvSata].
sd 1:0:0:0: [sdb] Sector size 0 reported, assuming 512.
sd 1:0:0:0: [sdb] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
sd 1:0:0:0: [sdb] 0-byte physical blocks
sd 0:0:0:0: Attached scsi generic sg0 type 0
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Mode Sense: 23 00 10 00
sd 1:0:0:0: Attached scsi generic sg1 type 0
sd 1:0:0:0: [sdb] Write Protect is off
sd 1:0:0:0: [sdb] Mode Sense: 23 00 10 00
sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, supports DPO and FUA
SPI Serial flash detected @ 0xf4000000, 16384KB (64sec x 256KB)
Creating 6 MTD partitions on "spi_flash":
0x000000000000-0x000000080000 : "U-Boot"
sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, supports DPO and FUA
sd 0:0:0:0: [sda] Sector size 0 reported, assuming 512.
0x000000200000-0x000000400000 : "Kernel"
sdb:
0x000000400000-0x000000d00000 : "RootFS"
0x000000d00000-0x000001000000 : "RootFS2"
sda:
0x000000080000-0x0000000c0000 : "U-Boot Config"
0x0000000c0000-0x000000200000 : "NAS Config"
Loading Marvell Ethernet Driver:
o Cached descriptors in DRAM
o DRAM SW cache-coherency
o 1 Giga ports supported
o Single RX Queue support - ETH_DEF_RXQ=0
o Single TX Queue support - ETH_DEF_TXQ=0
o TCP segmentation offload (TSO) supported
o Large Receive offload (LRO) supported
o Receive checksum offload supported
o Transmit checksum offload supported
o Network Fast Processing (Routing) supported - (Disabled)
o Proc tool API enabled
o SKB Reuse supported - (Disabled)
o SKB Recycle supported - (Disabled)
o Rx descripors: q0=128
o Tx descripors: q0=532
o Loading network interface(s):
o register under mv88fx_eth platform
sdb1 sdb2 sdb3 sdb4
sda1 sda2 sda3 sda4
o eth0, ifindex = 2, GbE port = 0
mvFpRuleDb (00000010): 0 entries, 0 bytes
Marvell debug tracing is on
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci_marvell ehci_marvell.70059: Marvell Orion EHCI
ehci_marvell ehci_marvell.70059: new USB bus registered, assigned bus number 1
sd 0:0:0:0: [sda] Attached SCSI disk
ehci_marvell ehci_marvell.70059: irq 19, io base 0xf1050100
sd 1:0:0:0: [sdb] Attached SCSI disk
ehci_marvell ehci_marvell.70059: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usb: create proc systemp successfully
mice: PS/2 mouse device common for all mice
md: raid1 personality registered for level 1
md: raid6 personality registered for level 6
md: raid5 personality registered for level 5
md: raid4 personality registered for level 4
TCP cubic registered
NET: Registered protocol family 17
rtc kw_rtc: setting system clock to 2011-04-20 08:39:57 UTC (1303288797)
md: Waiting for all devices to be available before autodetect
md: If you don't use raid, use raid=noautodetect
md: Autodetecting RAID arrays.
md: Scanned 0 and added 0 devices.
md: autorun ...
md: ... autorun DONE.
RAMDISK: gzip image found at block 0
usb 1-1: new high speed USB device using ehci_marvell and address 2
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
VFS: Mounted root (ext2 filesystem) on device 1:0.
Freeing init memory: 136K
kjournald starting. Commit interval 5 seconds
EXT3-fs (sda1): mounted filesystem with writeback data mode
EXT3-fs (sdb1): mounted filesystem with writeback data mode
md: md9 stopped.
md: bind<sdb1>
md: bind<sda1>
raid1: raid set md9 active with 2 out of 2 mirrors
md9: bitmap initialized from disk: read 5/5 pages, set 0 bits
created bitmap (65 pages) for device md9
md9: detected capacity change from 0 to 542769152
md9: unknown partition table
EXT3-fs (md9): using internal journal
EXT3-fs (md9): mounted filesystem with writeback data mode
md: md13 stopped.
md: bind<sdb4>
md: bind<sda4>
raid1: raid set md13 active with 2 out of 2 mirrors
md13: bitmap initialized from disk: read 4/4 pages, set 0 bits
created bitmap (57 pages) for device md13
md13: detected capacity change from 0 to 469893120
md13: unknown partition table
EXT3-fs (md13): using internal journal
EXT3-fs (md13): mounted filesystem with writeback data mode
fuse init (API version 7.13)
NET: Registered protocol family 5
md: linear personality registered for level -1
md: raid0 personality registered for level 0
device-mapper: ioctl: 4.16.0-ioctl (2009-11-05) initialised: dm-devel@redhat.com
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
usbcore: registered new interface driver usblp
sysinfo: Module loaded.
ufsd: module license 'Commercial product' taints kernel.
Disabling lock debugging due to kernel taint
ufsd: driver U82 (Mar 31 2011 03:21:53) LBD=OFF with ioctl loaded at bf17e000
NTFS read/write support included
Hfs+/HfsX read/write support included
Slow work thread pool: Starting up
Slow work thread pool: Ready
lib80211: common routines for IEEE802.11 drivers
lib80211_crypt: registered algorithm 'NULL'
cfg80211: Calling CRDA to update world regulatory domain
Enable WDT...
usbcore: registered new interface driver snd-usb-audio
usbcore: registered new interface driver snd-usb-caiaq
eth0: mac address changed
eth0: link down
eth0: started
eth0: link up, full duplex, speed 100 Mbps
md: bind<sda2>
raid1: raid set md2 active with 1 out of 1 mirrors
md2: detected capacity change from 0 to 542769152
md2: unknown partition table
Adding 530040k swap on /dev/md2. Priority:-1 extents:1 across:530040k
md: bind<sdb2>
RAID1 conf printout:
--- wd:1 rd:2
disk 0, wo:0, o:1, dev:sda2
disk 1, wo:1, o:1, dev:sdb2
md: recovery of RAID array md2
md: minimum _guaranteed_ speed: 5000 KB/sec/disk.
md: using maximum available idle IO bandwidth (but not more than 200000 KB/sec) for recovery.
md: Recovering started: md2
md: using 128k window, over a total of 530048 blocks.
active port 0 :139
active port 1 :445
active port 2 :20
md: md2: recovery done.
md: Recovering done: md2, degraded=1
--- wd:2 rd:2
disk 1, wo:0, o:1, dev:sdb2
md: md0 stopped.
md: md0 stopped.
md: md0 stopped.
md: bind<sdb3>
md: bind<sda3>
raid1: raid set md0 active with 2 out of 2 mirrors
md0: detected capacity change from 0 to 1998792294400
md0: unknown partition table
EXT4-fs (md0): mounted filesystem with ordered data mode
eth0: stopped
eth0: link down
eth0: started
eth0: stopped
eth0: started
active port 0 :139
active port 1 :445
active port 2 :20
warning: `proftpd' uses 32-bit capabilities (legacy support in use)
warning: process `pic_raw' used the deprecated sysctl system call with 8.1.2.
rule type=2, num=0
Loading iSCSI transport class v2.0-871.
iscsi: registered transport (tcp)
