what is manarequest.cgi?
I have been having issues with the performance of my TS-419P II so I called the tech support and they found a process on my NAS called manarequest.cgi that is taking up a lot of CPU. They didn't have any idea what it was and were going to do a little research for me. Does anyone know what this is from? Thanks.
- schumaku
Re: what is manarequest.cgi?
...and of course you have seen the manaRequest.cgi process(es) in System Status >> Ressource Monitor
It's the data collection process doing the Ressource Monitor (CPU Usage, Memory Usage, ..., Processes). So a chicken and egg problem. Use Linux command shell if you don't want to see side effects of the Web UI processing.
I have noticed this also on my TS-419P II. And I also have performance issues with this system. There are up to 4 entries for manarequest.cgi in the resource monitor, but it goes down to 2 after a while. Still confusing how this all works, why can't there be one instance an that is it?
If not even the qnap people know what is going on, this is not a good sign. The vendor should know the details.
- schumaku
There is a lot of information made available - direct visible or hidden - in the QTS desktop. All this data must be captured and prepared on the NAS in the background, and for applying administration changes.
Are these processes becoming CPU-bound, becoming a major load on your NAS?StardustOne wrote:There are up to 4 entries for manarequest.cgi in the resource monitor, but it goes down to 2 after a while.
Thats B.S. - QNAP does certainly know for what purpose each processes is in place and active when required. There was one minor issue with this cgi which could have made it to a resource hog (CPU and/or memory), fixed more than two years ago. The faster the NAS, the less are these manarequest.cgi becoming visible.StardustOne wrote:If not even the qnap people know what is going on, this is not a good sign.
[~] # find / -name *manaRequest*
[~] # /mnt/ext/home/httpd/cgi-bin/management/manaRequest.cgi
Content-type: text/xml
<?xml version="1.0" encoding="UTF-8" ?>
<QDocRoot version="1.0">
<authPassed><![CDATA[0]]></authPassed></QDocRoot>
when i do cat
??U?p??`??8
?AT?OT?:T?_*???
??%??6????0??\?
8@!?? 0a?a??4s??A??8@
?&????????????*????????r?8P ?%8??H??R??@???I?*R?E?@b???????P????_?8??
8??#8???R??0??PE?*R??PE? ??0???U????M?0????@?L
?H0
?\?LK???
p???(?K???T??????`?V?_:V?*???
??d$??6????0???\????&???*???@f?????????p????!?8? 8??H??R??@??pG?*R???@b????u??P?????8 8???#8???R??0??PE?*R??PE?? 0????U?):U??*??0??x#??<????0???^?)
W?
??? ??80S?
0??:0??0??????
0???????p??????@?
?S?F???@r?P??@ ??@
?@????V???? ???????U??0?? ???????T???? ???>???8P:?? j?6???:??7B??(???5"?x??Z?? ??'x????0
????< 0??,8??H??R? ?@??@?<
?*R??@@??<
?@b? ????? ??`?????0 8???#8???R???`F?*R???`F?<0 b???.Ƞ?%8??
?????????????8?"H?? 8??R: ??_
8P0??
T?S?0??0?N
N?0??&???8i??9??&?????? i??7B??*???0"????4
????p????`?4 "8???H??R??@??pG?*R??pG?@??@b??????P????K?4@?8??#8???R????PE?*R??PE???8?@b?ɠ????8?
?????-??L??M?̅??@??P??S? ??8 ??????????????????0???5?????????????????0????,?????????0??????I?@?????pG?@????? ?????8??
?0??p????D
?@0
?`??AT?]T?*?T?G??? ???|%??6????0???\?
8,?? 0l?l??0s??
??8
?&?????????O??*??????????8 "8?? ?H??R??@???I?*R?8?@b????;??P??????8?8??#8???R??0??PE?*R??PE? ??0??`?U????[U?a:U??*??0??p$??<????0???^?f
W?
??? ??80S?
0??:0??0????C
0????B?T??????`?V?E:V??*???
???#??6????0???\?????&???*???@f??????????p?????8? 8??H??R??@??pG?*R???@b???????P????u?8 8???#8???R??0??PE?*R??PE?? 0???0????D
?@0
?DK???(?K????U??0?? ??????V???? ??????T?*???
??O???8:?? j?6???:??7B??(???0"?x??Z?? ??'x????0
???;?< 0? 8??H??R? ?@??A?<
?*R??A@??<
?@b? ????? ??`????"?0 8???#8???R???`F?j:<0 b???.Ƞ?%8??
?????????????8?"H?? 8??R: ??d
80??
T?Q?0??0?U
N?0?????8i??9??&?????? i?*???7B??1"?????4
?Q??p??????4 "8???H??R??@??pG?*R??pG?@??@b????<??P??????4?8??#8???R????PE?*R??PE???8@b??????8
?1???0?????0????????????????????????????????????0?????R?????`F??????B???pG?@??%????I?@?????? ???????? Q??/?:P???
?o?/o?0B???0c?1?? ??????P?@ ??? ??P?@ ??? ??P?@ ??? ??P?@ ??? ??P?@ ??? ??P?@ ??? ??P?@ ??? ??P?@ ??? ??P?@ ??? ??P?@ ??? ??P?@ ??? ??P?@ ??? ??P?@ ??? ??P?@ ??? ??P?@ ??? ??P?@ ??? ??P?@ ??? ??P?@ ??? ??P?@ ??? ??P?@ ??? ??P?@ ??? ??P??????-??L?P`??`????????p??e???<0??< ??0b?CQ?? ??P?@ ??? ??P?@ ??? ??P?@ ??? ??P?@ ??? ??P?@ ??? ??P?@ ??? ?????/????/?/o? b?0???/?-?????@-?`???@???A??/?@-????????/?
????-??L????QUERY_STRING&%XCONTENT_LENGTH??????????? ????@??(?4?`?<???H???P?\?h???p?????????????? ??d????
d?p??????????????????????,???8?`?t???????? ???????@??,?<?`?H?p???????????????????? ?<?D???P?l?|???????? ????@? ?H?\?`?p????????????????<?@???X? |???????!???????"? ??#D?X?@?l?$????`???%??
???$?&T?l???x?'???????(???????)0????@?*0??? ?@?+l?t?@???,????`???-??????.<?L???X?/|???????0????????1? ??4?2\?h? ?|?3????@?4????`???5??????6,?8???H?7h?|?????8????????9??? ?:L?h? ?t?;????@???<???`???=?(???<?>X?d? ?x??????????@???????A,?8??D?B`?x? ???C????@???D?(?`?4?E`?t?????F????????G$?????H0?4???@?I`??l?J???? ???K????@???L???`?(?MH?X???l?N????????O????????P?,???<?Q??h??t?R???? ???S????@???T?,?`?<?Uh?????x?V????????W????????X????8?l???ĵ?d??
05T;=LX <!I:#$PNV%&U'()*"+?@GJKQRSDE./,-AW1234789>HFBC/etc/dhcpc/dhcpcd-%s.info/etc/dhcpc/dhcpcd-%s.pid/sbin/dhcpcd -h "%s" -o 66,67,150 -T -t 30 %s 1>>/dev/null 2>&1/bin/kill -9 `/bin/cat %s 2>/dev/null` > /dev/null 2>&1IPADDR192.168.1.50</%s>
<%s><![CDATA[%s]]></%s>retStrdemositeretValue-11LDAPSupportADSSupportdnsresolve/sbin/dns_resolve google.com > /dev/null 2>&1dnsResolveOk/sbin/dns_resovle yahoo.com > /dev/null 2>&1sleepSupportsetting_resultauthSid%sauthPassedDemoSiteSuppurtnohostnamespecVersion1.0QDocRoot<%s>trustedDomainenabletrusteddomainnetbiospasswdConstraintspasswdConstraint01passwdConstraint02passwdConstraint03passwdConstraint04selectmultiplesingleheightmaxEntryfuncownContent<%s %s='%s'>Content-type: text/xml%c%c%c%c<?xml version="1.0" encoding="UTF-8" ?><QDocRoot version="1.0"> icon Icon Name: %s
url Url: %s
thumbImg ThubmImage: %s
image Image: %s
imageOpen ImageOpen: %s
tooltip Tooltip: %s
imageMouseover ImageMouseover: %s
titledescriptionchildGrouphelpUrl %s
/>%s</%s>
/tmp/raidmng.statusVOLUME%dRAIDMNGvolumeListlinearstripmirrorraid5raid6raid10unknown %d volumeis_default_volumevolumeStatvolumeDisksvolumeStatusvolumeMngStatusStorageSupport RAID 5Support Hot SparesparespareDiskvolumeValuefreeSize%lldfstypevdd QKVMPrivate_Confignull/etc/config/qpkg.conf%s/config/config.confbr%dInterfaceeth0autonetworkRate1000MTU1500currentMTUmacAddresseth1eth2eth3lan5_infonetmaskgatewaystartIPendIPprimaryDNSsecondDNSWINSserverTFTPIPtftp_start_iptftp_end_ipStaticIPStaticNetmaskStaticGatewayIP1IP2IP3IP4WebUIIPInfointerfaceIdinterfaceNameinterfaceMemberinterfaceIndexbridgeQKVMURL%s?inf=%sSTANDALONEbalance-rractive-backupbalance-xorbroadcast802.3adbalance-tlbbalance-alberrorbondingTypeVlanSupportedIPTypedhcpstaticinterfaceNumberdhcpServerleaseDayleaseHourdomain_nametftpserverbootfileShareNumiso_countiso_max_countGroupNumUserNumguestgroupListeveryoneadministratorscommentgqMasterfirmwareversionbuildpatch2013-01-01/etc/default_config/uLinux.confSystemBuild Date%s/%s/%s%s.%s.%s%s-%s-%sbuildTimemodelTS-119TS-219modelName%s+%s IITS-120TS-220TS-420TS-420UTS-121TS-221TS-421TS-421UHS-210TS-112TS-112PTS-212TS-212PTS-412internalModelNameplatformcustomModelNamedisplayModelName<storage_v2>0</storage_v2>aboutsoftwareVersionsoftwareBuildhardwareVersioncustomLogocustomFrontLogocustomLoginLogo/proc/meminfoCan't open /proc/meminfo
contextMenuDISABLE/var/.application.conf/bin/rm -f %s 1>>/dev/null 2>&1/sbin/dhcpcd -h "%s" -T -t 30 %s 1>>/dev/null 2>&1upperlowerfilterrefresh<grouproot> <count>%d</count>
<data><group>groupname <checkbox>checkbox</checkbox></group> </data> <ret>%d</ret>
</grouproot><userroot><user>username</user></userroot>userNamegroupName@%s,%s%dISOShareDestnone/etc/config/iso_share_mappingexternalsharerootdatasharesharenameis_gqpreviewret/cgi-bin/sys/html/sys_setting.html/ajax_obj/images/icon_system_1_s.gif/ajax_obj/images/icon_system_1_L.gif/cgi-bin/sys/html/net_setting.html/ajax_obj/images/icon_system_2_s.gif/ajax_obj/images/icon_system_2_L.gif/cgi-bin/sys/html/hardware.html/ajax_obj/images/icon_system_3_s.gif/ajax_obj/images/icon_system_3_L.gif/cgi-bin/sys/html/security.html/ajax_obj/images/icon_system_4_s.gif/ajax_obj/images/icon_system_4_L.gif/cgi-bin/sys/html/notification.html/ajax_obj/images/icon_system_5_s.gif/ajax_obj/images/icon_system_5_L.gif/cgi-bin/sys/html/power_mgmt.html/ajax_obj/images/icon_system_6_s.gif/ajax_obj/images/icon_system_6_L.gif/cgi-bin/sys/html/net_recyclebin.html/ajax_obj/images/icon_system_7_s.gif/ajax_obj/images/icon_system_7_L.gif/cgi-bin/sys/html/sys_logs.html/ajax_obj/images/icon_system_9_s.gif/ajax_obj/images/icon_system_9_L.gif/cgi-bin/sys/html/firm_update.html/ajax_obj/images/icon_system_10_s.gif/ajax_obj/images/icon_system_10_L.gif/cgi-bin/disk/html/disk_mgmt.html/ajax_obj/images/icon_disk_1_s.gif/ajax_obj/images/icon_disk_1_L.gif/cgi-bin/disk/html/raid_mgmt.html/ajax_obj/images/icon_disk_2_s.gif/ajax_obj/images/icon_disk_2_L.gif/cgi-bin/disk/html/smart.html/ajax_obj/images/icon_disk_3_s.gif/ajax_obj/images/icon_disk_3_L.gif/cgi-bin/disk/html/encrypt_fs.html/ajax_obj/images/icon_disk_4_s.gif/ajax_obj/images/icon_disk_4_L.gif/cgi-bin/disk/html/iscsi.html/ajax_obj/images/icon_disk_5_s.gif/ajax_obj/images/icon_disk_5_L.gif/cgi-bin/priv/html/user.html/ajax_obj/images/icon_privilege_1_s.gif/ajax_obj/images/icon_privilege_1_L.gif/cgi-bin/priv/html/group.html/ajax_obj/images/icon_privilege_2_s.gif/ajax_obj/images/icon_privilege_2_L.gif/cgi-bin/priv/html/share.html/ajax_obj/images/icon_privilege_3_s.gif/ajax_obj/images/icon_privilege_3_L.gif/cgi-bin/net/html/ms_net.html/ajax_obj/images/icon_network_1_s.gif/ajax_obj/images/icon_network_1_L.gif/cgi-bin/net/html/apple_net.html/ajax_obj/images/icon_network_2_s.gif/ajax_obj/images/icon_network_2_L.gif/cgi-bin/net/html/nfs_srv.html/ajax_obj/images/icon_network_3_s.gif/ajax_obj/images/icon_network_3_L.gif/cgi-bin/net/html/ftp_srv.html/ajax_obj/images/icon_network_4_s.gif/ajax_obj/images/icon_network_4_L.gif/cgi-bin/net/html/tel_ssh.html/ajax_obj/images/icon_network_5_s.gif/ajax_obj/images/icon_network_5_L.gif/cgi-bin/net/html/web_srv.html/ajax_obj/images/icon_network_6_s.gif/ajax_obj/images/icon_network_6_L.gif/cgi-bin/application/html/mysql_srv.html/ajax_obj/images/icon_ application_7_s.gif/ajax_obj/images/icon_ application_7_L.gif/cgi-bin/application/html/web_file_mgmt.html/ajax_obj/images/icon_ application_1_s.gif/ajax_obj/images/icon_ application_1_L.gif/cgi-bin/application/html/qmultimedia.html/ajax_obj/images/icon_ application_2_s.gif/ajax_obj/images/icon_ application_2_L.gif/cgi-bin/application/html/qdownload.html/ajax_obj/images/icon_ application_3_s.gif/ajax_obj/images/icon_ application_3_L.gif/cgi-bin/application/html/survielance.html/ajax_obj/images/icon_ application_4_s.gif/ajax_obj/images/icon_ application_4_L.gif/cgi-bin/application/html/iTunes.html/ajax_obj/images/icon_ application_5_s.gif/ajax_obj/images/icon_ application_5_L.gif/cgi-bin/application/html/upnp.html/ajax_obj/images/icon_ application_6_s.gif/ajax_obj/images/icon_ application_6_L.gif/cgi-bin/application/html/medialib.html/ajax_obj/images/icon_application_ms_s.gif/ajax_obj/images/icon_application_ms_L.gif/cgi-bin/application/html/transcode.html/cgi-bin/application/html/qpkg.html/ajax_obj/images/icon_ application_8_s.gif/ajax_obj/images/icon_ application_8_L.gif/cgi-bin/backup/html/back_to_ext.html/ajax_obj/images/icon_backup_1_s.gif/ajax_obj/images/icon_backup_1_L.gif/cgi-bin/backup/html/one_button.html/ajax_obj/images/icon_backup_2_s.gif/ajax_obj/images/icon_backup_2_L.gif/cgi-bin/backup/html/cloudbackup.html/ajax_obj/images/icon_backup_CloudBackup_s.png/ajax_obj/images/icon_backup_CloudBackup_L.png/cgi-bin/backup/html/timemachine.html/cgi-bin/backup/html/conf_backup.html/ajax_obj/images/icon_system_8_s.gif/ajax_obj/images/icon_system_8_L.gif/cgi-bin/devices/html/usb_disk.html/ajax_obj/images/icon_ device_4_s.gif/ajax_obj/images/icon_ device_4_L.gif/cgi-bin/devices/html/usb_printer_CUPS.html/ajax_obj/images/icon_ device_2_s.gif/ajax_obj/images/icon_ device_2_L.gif/cgi-bin/devices/html/esata.html/ajax_obj/images/icon_ device_5_s.gif/ajax_obj/images/icon_ device_5_L.gif/cgi-bin/devices/html/ups.html/ajax_obj/images/icon_ device_3_s.gif/ajax_obj/images/icon_ device_3_L.gif/cgi-bin/sys/html/sys_reset.html/ajax_obj/images/icon_system_11_s.gif/ajax_obj/images/icon_system_11_L.gif/cgi-bin/priv/html/usr_quota.html/ajax_obj/images/icon_privilege_4_s.gif/ajax_obj/images/icon_privilege_4_L.gif/cgi-bin/management/html/sysinfo.html/ajax_obj/images/icon_status_1_s.gif/ajax_obj/images/icon_status_1_L.gif/cgi-bin/management/html/netinfo.html/ajax_obj/images/icon_status_3_s.gif/ajax_obj/images/icon_status_3_L.gif/cgi-bin/management/html/sysmonitor.html/ajax_obj/images/icon_status_2_s.gif/ajax_obj/images/icon_status_2_L.gif/cgi-bin/net/html/net_srv.html/ajax_obj/images/icon_network_8_s.gif/ajax_obj/images/icon_network_8_L.gif/cgi-bin/disk/html/snapshot.html/ajax_obj/images/icon_disk_6_s.gif/ajax_obj/images/icon_disk_6_L.gif/cgi-bin/net/html/snmp.html/ajax_obj/images/icon_network_9_s.gif/ajax_obj/images/icon_network_9_L.gif/cgi-bin/disk/html/vdd.html/ajax_obj/images/icon_disk_7_s.gif/ajax_obj/images/icon_disk_7_L.gif/cgi-bin/application/html/logserver.html/cgi-bin/application/html/radius.html/ajax_obj/images/icon_application_9_s.gif/ajax_obj/images/icon_application_9_L.gif/cgi-bin/backup/html/mozy.html/ajax_obj/images/icon_mozy_S.png/ajax_obj/images/icon_mozy_L.png/cgi-bin/my_cloud/html/ddns.html/ajax_obj/images/icon_cloud_1_s.gif/ajax_obj/images/icon_cloud_1_L.gif/cgi-bin/my_cloud/html/upnpc.html/ajax_obj/images/icon_cloud_2_s.pnp/ajax_obj/images/icon_cloud_2_L.gif/cgi-bin/backup/html/bak_server.html/ajax_obj/images/icon_application_backup_server_s.png/ajax_obj/images/icon_application_backup_server_L.png/cgi-bin/backup/html/remote_rep.html/ajax_obj/images/icon_backup_3_s.gif/ajax_obj/images/icon_backup_3_L.gif/cgi-bin/my_cloud/html/cloudnas_wizard.html/ajax_obj/images/icon_cloud_3_s.gif/ajax_obj/images/icon_cloud_3_L.gif/cgi-bin/application/html/qlicense.html/cgi-bin/management/html/rss.html/ajax_obj/images/rss.png/ajax_obj/images/rss_icon_l.gif/cgi-bin/net/html/yoics.html/ajax_obj/images/icon_network_10_s.gif/ajax_obj/images/icon_network_10_L.gif/cgi-bin/application/html/antivirus.html/ajax_obj/images/icon_application_av_s.png/ajax_obj/images/icon_application_av_L.png/cgi-bin/application/html/tftp.html/ajax_obj/images/icon_application_tftp_s.gif/ajax_obj/images/icon_application_tftp_L.gif/cgi-bin/priv/html/ldap.html/ajax_obj/images/icon_privilege_5_s.gif/ajax_obj/images/icon_privilege_5_L.gif/cgi-bin/sys/html/service_binding.html/ajax_obj/images/icon_system_12_s.gif/ajax_obj/images/icon_system_12_L.gif/cgi-bin/application/html/musics.html/cgi-bin/application/html/videos.html/ajax_obj/images/icon_application_vs_s.gif/ajax_obj/images/icon_application_vs_L.gif/cgi-bin/application/html/photos.html/ajax_obj/images/icon_application_ps_s.gif/ajax_obj/images/icon_application_ps_L.gif/cgi-bin/application/html/vpn_service.html/ajax_obj/images/icon_application_vpn_s.png/ajax_obj/images/icon_application_vpn_L.png/cgi-bin/application/html/vpn_client.html/ajax_obj/images/icon_application_vpnclient_s.png/ajax_obj/images/icon_application_vpnclient_L.png/cgi-bin/application/html/ldapserver.html/cgi-bin/disk/html/enclosure_mgmt.html/cgi-bin/application/html/hdstation.html/ajax_obj/images/icon_application_hd_station_s.png/ajax_obj/images/icon_application_hd_station_L.png/cgi-bin/backup/html/qbox.html/ajax_obj/images/icon_qbox_s.gif/ajax_obj/images/icon_qbox_L.gif/cgi-bin/priv/html/application_privilege.htmlHomeMENU_1SYS_TITLESYS_DESCMENU_2DISK_TITLEDISK_DESCMENU_3PRIV_TITLEPrivilegesMENU_4NET_TITLEMENU_5APP_TITLEApplicationMENU_6BACKUP_TITLEBackupMENU_7DEVICE_TITLEMENU_8MANAGEMENT_TITLEMENU_9CLOUD_TITLEMyCloudNASMENU_10/help/help_my_cloud_nas.html#V3_MENU_STR02/help/help_system.html#GeneralV3_MENU_STR03/help/help_system.html#NetworkHardwareIEI_NAS_MISC3/help/help_system.html#HardwareSecurityS_MENU_4/help/help_system.html#SecurityNotificationS_MENU_5/help/help_system.html#NotificationPower ManagementS_MENU_6/help/help_system.html#Power_ManagementNetwork Recycle BinS_MENU_7/help/help_system.html#Network_Recycle_BinSystem LogS_MENU_8/help/help_system.html#System_LogFirmware UpdateS_MENU_9/help/help_system.html#Firmware_UpdateDisk ManagementS_MENU_11/help/help_disk.html#Volume_ManagementRAID ManagementIEI_DEVICE_TITLE06/help/help_disk.html#RAID_ManagementDisk S.M.A.R.T.IEI_NAS_MISC13/help/help_disk.html#HDD_SMARTEncrypted FilesystemS_MENU_12/help/help_disk.html#ENCFSiSCSIS_MENU_13/help/help_disk.html#ISCSIUser ManagementIEI_NAS_SECURITY1/help/help_privilege.html#UserGroup ManagementIEI_NAS_SECURITY2/help/help_privilege.html#User_GroupShare ManagementS_MENU_16/help/help_privilege.html#Shared_FolderMicrosoft NetworkIEI_NAS_NETWORK2/help/help_network.html#Microsoft_NetworkingApple NetworkNIC_APPLE_STR01/help/help_network.html#Apple_NetworkingNFS NetworkNIC_NAS_SERVICE_STR06/help/help_network.html#Linux_NFS_ServiceFTPNIC_NAS_SERVICE_STR10/help/help_network.html#FTP_ServiceTelnet/SSHMISC_LOGIN_STRING01/help/help_network.html#Telnet_SSHWeb StationNIC_WEB_STR01/help/help_network.html#Web_ServerMySQLNIC_MYSQL_STR01/help/help_application.html#MySQL_ServerWeb File ManagemerIEI_NAS_NETWORK5/help/help_application.html#Web_File_ManagerMultimedia StationNIC_NAS_SERVICE_STR14/help/help_application.html#Multimedia_StationDownload StationIEI_DOWN_STATION_TITLE/help/help_application.html#Download_StationSurveillance StationS_MENU_30/help/help_application.html#Surveillance_StationNIC_ITUNES_SERVEICE/help/help_application.html#iTunes_StationUPNPS_MENU_42/help/help_application.html#UPnP_MediaServerMedia Library/help/help_application.html#Media_LibraryQPKGS_MENU_73/help/help_application.html#QPKG_PluginsBack To ExternalS_MENU_33/help/help_backup.html#External_DeviceOne Button CopyMISC_USB_COPY_STRING01/help/help_backup.html#USB_OTCCloud BackupS_MENU_35/help/help_backup.html#CLOUD_BACKUPTime machineMISC_TIMEMACHINE_STR01/help/help_backup.html#Time_machineBackup ConfigurationS_MENU_36/help/help_system.html#System_SettingsUSB DiskIEI_DEVICE_TITLE03/help/help_device.html#External_DriveUSB PrinterIEI_DEVICE_TITLE04/help/help_device.html#USB_PrintereSATA DiskS_MENU_39UPSUPS_STRING1/help/help_device.html#UPSSystem ResetS_MENU_10_Athens/help/help_system.html#System_ResetUser QuotaIEI_NAS_QUOTA/help/help_privilege.html#QuotaSystem InformationS_MENU_40/help/help_management.html#System_InformationNetwork SettingsS_MENU_45/help/help_management.html#Network_SettingsSystem MonitorS_MENU_41/help/help_management.html#Resource_MonitorNetwork Service DiscoveryS_MENU_44/help/help_network.html#Network_Service_DiscoverySnapshotSNAPSHOT_MANAGEMENT/help/help_disk.html#SNAPSHOTIEI_NAS_MISC00/help/help_network.html#SNMPVirtual DiskIEI_DEVICE_TITLE11/help/help_disk.html#VDDView LogsS_MENU_57_Athens/help/help_management.html#View_LogSysLog ServerS_MENU_59/help/help_application.html#Syslog_ServerRadius ServerS_MENU_60/help/help_application.html#Radius_ServerMozy BackupS_MENU_61/help/help_backup.html#MozyConfig MyCloudNAS NameS_MENU_64/help/help_my_cloud_nas.html#Config_MyCloudNAS_NameAuto Router ConfigurationS_MENU_65/help/help_my_cloud_nas.html#Auto_Router_ConfigurationBackup ServerS_MENU_62/help/help_application.html#BACKUP_SERVERRemote ReplicationS_MENU_63/help/help_backup.html#Remote_ReplicationMyCloudNAS WizardS_MENU_67/help/help_my_cloud_nas.html#MyCloudNAS_WizardS_MENU_66/help/help_application.html#QLicenseRSSS_MENU_RSS/help/help_management.html#RSSS_MENU_71/help/help_network.html#YoicsIEI_AV_TITLE/help/help_application.html#ClamAVNIC_MS_STR38/help/help_application.html#TFTPDomain Security(LDAP /AD )DOMAIN_SECURITY_STR01/help/help_privilege.html#LDAPService BindingSERVICE_BIND_TITLE/help/help_system.html#SERVBINDMusic StationMUSIC_STR01/help/help_application.html#Music_StationVIdeo StationVIDEO_STR01/help/help_application.html#Video_StationPhoto StationQNAP_PS_STR01/help/help_application.html#Photo_StationVPN_SERVICE/help/help_application.html#VPNVPN_CLIENT/help/help_application.html#VPNCLIENTLDAP serverLDAP_SERVER_STR01/help/help_application.html#LDAPSERVERJBOD Expansion EnclosureJBOD_FUNC_TITLE/help/help_disk.html#Enclosure_ManagementSurveillance Station ProQLICENSE_STR45HD StationHD_STATION/help/help_application.html#HD_StationQboxQBOX_STR01/help/help_backup.html#QboxApplication PrivilegeAPPLICATION_PRIVILEGE_STR01/help/help_application.html#Application_Privilegeeth0???????????????????????????????????????????sysHealthprocesslistsys_cpu_usesys_memory_usetaskNowProcessingtaskDonelistsidapplysubfuncitemeventIDdetailhddNOhostNOpowerNOfanNO/tmp/device_sata_refresh.flag/proc/tsinfo/systempmedialibTCSPausetaskhdsmarthd%dprogressjobIDNowTestTypeantiVirus/etc/qsync/extdrv.confbackupExternal%ldjob_statisticjob_files%lujob_retryjob_countdown/etc/qsync/qsync.confbackupRTRRbackupRsyncpidErrorbackupNAStoNAS/etc/config/lunporter/lunporter.confbackupLUNmediaLibfacilitypathmytranscodesvrusermediaLibScanningthGenremainblockscanningbackupAmazons3--sys_memory_infomem_total%umem_usedmem_freeswap_totalswap_usedswap_freeprocessInfoItermproc_namepidcpu_us%.2fmem_ussys_cpu_infocpu_countitermcpuIdcpu_usage0 %%%.1f %%<sys_tempc>%d</sys_tempc>
<sys_tempf>%d</sys_tempf>
SysTempWarnTSysTempErrT<disk_num>%d</disk_num>
<tempc%d>--</tempc%d>
<tempf%d>--</tempf%d>
<tempc%d>%d</tempc%d>
<tempf%d>%d</tempf%d>
/proc/net/wirelessInterface/sbin/ifconfig %sUP/etc/resolv.confdnsInfonameserverDNS_LISTbondBonding Membereth%s<eth_ipv6_%d>%s</eth_ipv6_%d>
NULL255.255.255.0169.254.100.100eth%d<eth_ip%d>%s</eth_ip%d>
<eth_mask%d>%s</eth_mask%d>
ErrorPlease check bonding value.<eth_status%d>%d</eth_status%d>
max speed/var/option_extra_lan<eth_max_speed%d>%d</eth_max_speed%d>
MAC00:00:00:00:00:00/var/MacAddress<eth_mac%d>%s</eth_mac%d>
Usage<eth_usage%d>%s</eth_usage%d>
serial number/var/hw_serial_number/sbin/get_hwsn 1>>/dev/null 2>&1<serial_number>%s</serial_number>
MiscCustom Tempsystem stop temp/proc/net/devwlan%dLinkInfowirelessiptypeYES/etc/config/wpa_supplicant.confssid/etc/config/wireless.confAP_StatusAP_SSID0.0.0.0/sbin/ifconfig %s 2> /dev/nullHWaddr<rx_packet_wlan0>%llu</rx_packet_wlan0>
<tx_packet_wlan0>%llu</tx_packet_wlan0>
<err_packet_wlan0>%llu</err_packet_wlan0>
inet addr:Mask:MTU:GATEWAYDefault GW Devicewlan0WirelessSupportroottimezonetotal_memory%.1ffree_memorynic_cnt<rx_packet%d>%llu</rx_packet%d>
<tx_packet%d>%llu</tx_packet%d>
<err_packet%d>%llu</err_packet%d>
ipv6Enable/proc/uptimeuptime_dayuptime_houruptime_minuptime_sechdHDTempWarnTHDTempErrTserver_namecodepage/etc/config/smb.confgloballocal masteryesqmultimediaQMultimediaEnabledfunciTunesupnpfuncTwonkyqdownloadQDownloadEnabledlanInfomsServerEnabledlanTypeeth0SpeedtypeUse DHCPFALSETRUEeth0ConnecttypeSTATICeth0Ipaddresseth0Netmasketh0Gatewayeth0Hwaddreth0_speed%d Mbpseth0statusdhcpserverEnablenetworkFileserviceworkgroupmsServertypeNTDCNTDMADDMADDCLDAPDMOtherwinsEnableddomainEnableddomaincontrollerSupportedntpserverSupportedappletalkEnabledappleZonenfsEnabledwebfsEnabledftpEnabledftpPortftpMaxinstancessnmpEnabledsnmpPort161hideHFqphotoEnabledmusicsEnabledphotosEnableditunesEnabledupnpEnabledqdmsEnableddownloadEnabledwebserverEnabledQWEB80webserverPortPHPregister_globalsOff/etc/config/php.iniregGlobalsEnabledshowYOICSddnsEnabledmysqlEnabledmysqlNetworkingradiusSupportedradiusEnabledsyslogServerSupportedsyslogServertcpEnabletcpPortudpEnableudpPortWeb Access Port8080sysPortqsurveillanceEnablebServiceEnableservicePort3260iscsiSupportedldapserverSupportedldapserverEnabledopenVPNSupportedopenvpnEnabledTCPopenVPNProtoUDPopenVPNPortpptpSupportedpptpEnabledtftpServerSupportedtftpEnabletftpUDPPortservBindSupportedGlobal/etc/config/service_binding.confservBindEnabledantivirusSupportedantivirusEnabledRsync SupportrsyncEnabled/etc/qsync/qsyncd.confRTRREnabledPWRS_%dINFO-1/etc/config/sysHealth.confFANS_%dalertI??????I??????ȱ?P????????????????{^q????3[k{??????%/JoytaskTypestartTimeendTimeendTimeSecLastTestTypeJobLastInfectedstartTimeSec
????h?H?x? L?
G
0?($?
???o?????o???o????`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?`?P
???D?
???(?P?p???????
?4?X????????? ?@?h????????(?L?p????????? ?D?h??????????8?`?????????@?h?????????$?L?l???????? ,?L?t?!??????"
?8?d?#??????$?D?p?%??????& ?L?x?'??????($?H?t?)??????* ?????+L?p???,?????-@?h???.?????/@???$?0h?????1???,?2T?????3?????4D?d???5?????6(?L?t?7??????8?<?d?9???????(?P?;x?????<???(?=P?l???> ?@?h????@?h?@??4?A`?????B?????C4?X?|?D?????E8?`???F?????G$????HL?p???I??????J?H?t?K??????L$?D?l?M??????N
?????O4?\???P????Q4?`???R?????SL?D?l?Tx?????U ?L?x?V?????W4?T?x?X??D?l?GCC: (GNU) 4.2.1GCC: (GNU) 4.2.1GCC: (GNU) 4.2.1GCC: (GNU) 4.2.1GCC: (GNU) 4.2.1GCC: (GNU) 4.2.1GCC: (GNU) 4.2.1GCC: (GNU) 4.2.1GCC: (GNU) 4.2.1GCC: (GNU) 4.2.1GCC: (GNU) 4.2.1GCC: (GNU) 4.2.1GCC: (GNU) 4.2.1A2aeabi(ARM10TDMI
hstrtab.interp.note.ABI-tag.hash.dynsym.dynstr.gnu.version.gnu.version_r.rel.dyn.rel.plt.init.text.fini.rodata.ARM.extab.ARM.exidx.eh_frame.init_array.fini_array.jcr.dynamic.got.data.bss.comment.ARM.attributes
4?4H?H !h?h'
x??/H?HG7???o???*?D???o???,?S
eL?L4``?`4?
h??p?h?q?+w?+@bP
???????????????????????0?0???ؒؒH
? ? ???p
