Cannot connect to App Centre
elektro
Post by elektro »
As of yesterday, when I click on 'All Apps' in the App Centre it states 'NAS could not retrieve App information list. Please check your network settings'
Nothing has changed, that I can recall, other than plugging in and unplugging external drives ot the USB ports..
Am connected via ethernet port, IP address 192.168.0.17, subnet mask 255.255.255.0, gateway 192.168.0.1, obtain DNS automatically.
I can connect via myQNAP cloud and don't seem to have any other issues.
Have tried to search for this issue but can't find any solutions.
Thanks.
scotland21
Know my way around
Re: Cannot connect to App Centre
Post by scotland21 »
I also have the same issue, any one else have this problem too?
elektro - did you find out the cause of this
TS-509pro 4.2.4, TS-809pro 4.2.4, TS-459II 4.2.4,TS-559II 4.2.4
TVS-663 4.3.3.0095, TS-853pro 4.3.3.0095, TVS-871 4.3.3.0095
Scotland21 8)
elektro
Post by elektro »
I didn't.. maybe something to do with network at the time, but the next day it reappeared all as normal and haven't had an issue since.
sergeleo
Post by sergeleo »
I have exactly the same issue after upgrading to 4.1.2
nasnoob
Getting the hang of things
Post by nasnoob »
same issue. Does QNAP support ever reply on these forums??
pwilson
Post by pwilson »
nasnoob wrote:same issue. Does QNAP support ever reply on these forums??
No they don't. This is not a QNAP Support channel. IF you want to read the QNAP Helpdesk, simply submit a ticket.
If you want assistance from the QNAP Community, you are in the right place.
You issue might be the same, but you are providing no information for us.
Questions:
  1. What Firmware Version/Build numbers are you using?
  2. What language is your Firmware in? English?
  3. Please access your NAS via SSH, login as "admin", and run:
    cat /etc/resolv.conf
    nslookup update.qnap.com
    #done
    Please cut&paste the output of these commands back to this message thread.
Patrick M. Wilson
Victoria, BC Canada
Zsolty
Post by Zsolty »
I have the same issue.
[~] # nslookup update.qnap.com
Server: dlinkrouter
Address: 192.168.0.1
Addresses: 93.179.210.170, 93.179.210.168
But still message "nas could not retrieve app information list"... Any recommendation? All appeared not much time ago.
schumaku
Contact:
Post by schumaku »
Potentially a temporary/volatile issue in the Akamai delivery network? Works here, some NAS tested get these IPs:
Server: (snip)
Address: (snip)
Addresses: 193.247.90.43, 193.247.90.50
Zsolty
Post by Zsolty »
nslookup works for me too, i have the ip, but still I cannot load the page with apps. In the same time Plex got inaccessible from outside, but it can be a coincidence too.
Return to “Miscellaneous”
