TS-212 4.1.1 build 20141101HDD never goes in stand-by mode
Discussion about hard drive spin down (standby) feature of NAS.
kjansik
First post
Post by kjansik »
My TS-212 4.1.1 build 20141101 HDD never goes in stand-by mode.
blkdevMonitor.sh shows:
---blkdevMonitor---
Countdown:
10
9
8
7
6
5
4
3
Turn on block_dump
Clean old dmesg
Start...
/dev/sda:
 issuing standby command
 setting standby immediately.
/dev/sdb:
/dev/sdc: No such device or address
/dev/sdd: No such device or address
/dev/sde: No such device or address
 drive state is:  active/idle
---counter=0---
Countdown:
10
9
8
7
6
5
4
3
/dev/sda:
/dev/sdb:
---counter=1---
Countdown:
10
9
8
7
6
5
4
3
/dev/sda:
/dev/sdb:
---counter=2---
Countdown:
10
9
8
7
6
5
4
3
/dev/sda:
/dev/sdb:
---counter=3---
Countdown:
10
9
8
7
6
5
4
3
/dev/sda:
/dev/sdb:
^C
If I understand it properly, after issuing standby command disk goes in active status immediately. I do not see any activity which can prevents disks go standby. Even if NAS is disconnected from network, disk is active every few seconds.
Any hint?
semtex87
Re: TS-212 4.1.1 build 20141101HDD never goes in stand-by m
Post by semtex87 »
I am having the same issue.
Every 3-4 seconds the disks make a disk read/write click sound as the heads move even though nothing is connected to the NAS, nothing is writing or reading from it. This happened after I made it a RO domain controller, I set replication to occur once an hour instead of 4 times an hour and the sound it makes when replicating is entirely different. It's about 5 seconds of disk activity when replicating, as opposed to it making a single click every 2-3 seconds continuously and never spins down even though it is idle.
This didn't happen before making it a RODC.
maxwello
Post by maxwello »
I too have this issue, where the disc does not enter standby. I use my NAS as a music server and I will often go a few days without using it and so I am keen to understand why it will not go into this mode.
Thanks for any help.
twil21
Post by twil21 »
I don't find the settings for the standby time.. Where is it?
Can anyone help me pleease.
pwilson
Post by pwilson »
kjansik wrote:My TS-212 4.1.1 build 20141101 HDD never goes in stand-by mode.
---blkdevMonitor---
Countdown:
10
9
8
7
6
5
4
3
Turn on block_dump
Clean old dmesg
Start...
/dev/sda:
/dev/sdb:
---counter=0---
Countdown:
10
9
8
7
6
5
4
3
/dev/sda:
/dev/sdb:
---counter=1---
Countdown:
10
9
8
7
6
5
4
3
/dev/sda:
/dev/sdb:
---counter=2---
Countdown:
10
9
8
7
6
5
4
3
/dev/sda:
/dev/sdb:
---counter=3---
Countdown:
10
9
8
7
6
5
4
3
/dev/sda:
/dev/sdb:
^C
Any hint?
What do the other 98 iterations look like? :roll: (Simply post the entire listing of all 100 iterations to "pastebin.com", and then provide the URL we can use to review it).
We can't troubleshoot properly with only 2% of the troubleshooting output provided.
Patrick M. Wilson
Victoria, BC Canada
Return to “HDD Spin Down (HDD Standby)”
