I have a QNAP TS-269 Pro with QTS 4.1.1 installed. I would like to set the checkmark at
System Settings / General Settings / Disable and hide the home/multimedia features such as ...
When I click on General Settings, the entry is there, but disappears. Does anyone know how to get it back?
Regards, Leonardo
Disable/hide home/multimedia features
Re: Disable/hide home/multimedia features
I've exactly the same weird behaviour. Clicking "System Settings" / "General Settings" shortly shows the "Disable and..." setting, but after loading finished it disappears. Very strange! Anybody knows a solution?
- Windows 8.1 with latest updates
- HS-210
- Firmware 4.1.1
- HS-210 connected to FritzBox 7490 via GBit Ethernet
- HS-210
- Firmware 4.1.1
- pwilson
There have been multiple "Builds" of QTS 4.1.1, which one are you folks complaining about?
It isn't difficult to provide this essential information when asking for assistance.
Perhaps you'd have better luck with QTS 4.1`2 Build 20141229
echo "Firmware: $(getcfg system version) Build $(getcfg system 'Build Number')"
Patrick M. Wilson
Victoria, BC Canada
Hi Patrick,
upgraded to QTS 4.1.2 build 20141229. But error is still there.
I made a small video that shows the behaviour, here are 3 frames chronologically extracted. In picture 2 you see the option available, but in picture 3 it's gone:
Strange, isn't it? Thanks Michael
- schumaku
I don't think it's a bug ... looks intentional. When you check the documentation you find some very few NAS series where this control is required. Further on, during new installations, the admin is challenged to select business or home type default installation. Afraid, I don't have the big picture on this part yet.
I also cannot see this but I cannot move on with this page though
https://www.qnap.com/en/how-to/faq/arti ... -settings/
I need to restore the shared folder path
TS-531P Annapurna
