Cannot disable admin account
In order to disable the admin account (TS-453A/ QTS 4.2.1) I followed the steps explained on https://www.qnap.com/en-us/tutorial/con ... ne&cid=137.
However, when I login using the new account it is not possible to select the original Admin account and deselect it.
How can I solve this issue?
Thanks in advance.
Thanks in advance.
- Spider99
Re: Cannot disable admin account
this is a bad idea as the admin account is fundamental to the way the nas works and lots of issues usually occur when its disabled
Tim
TS-853A(16GB): - 4.3.4.0483 - Static volume - Raid5 - 8 x 4TB HGST Deskstar NAS
Windows Server + StableBit Drivepool and Scanner ~115 TB Backup Server
TS-412 & TS-459 Pro II: Retired
Clients: 3 x Windows 10 Pro(64bit)
- Been there, done that
Just give your admin account a rediculously long and stupid password. Copy it somewhere and save it in case you ever need it for some reason. But never use it again unless you have to.
Thank you very much for the quick responses and recommendations. Really appreciated!
I am a bit confused, because it is qnap itself that recommends to disable the admin account in order to enhance security (see: https://www.qnap.com/en/tutorial/con_sh ... ne&cid=137 )
Nevertheless, it is not possible to disable the admin account, which should have been given the instructions of qnap. Is this a bug in the software?
- Spider99
Yes it is a bit odd that qnap did release that tutorial - but they also did not explain the consequences of disabling the admin account - sigh
for example - if you do disable admin you then cant ssh into the nas to do any admin as ssh only works with the admin account
as suggested above give the admin account a long complicated password if you are going to expose it to the internet - if its only going to be used within your lan then minimal risk to having an admin account
Tim
- schumaku
Lack of understanding of the QTS UI.... While the admin account can't be selected (as it would be required to [Delete] it!) there is an action item for "Edit Account Profile" ...FieldNas wrote:However, when I login using the new account it is not possible to select the original Admin account and deselect it.
...form there you can easily reach the Edit Account Profile shown in the tutorial.
For the supported NAS operations, and most others, the admin account can be disabled. The point is that it can't be removed, the admin entry must remain in passwd.Spider99 wrote:this is a bad idea as the admin account is fundamental to the way the nas works and lots of issues usually occur when its disabled
Not blaming the other community members here ... most don't' disable the admin account, because they want to retain the SSH (and probably last resort telnet) access.
Got it! I managed to "disable" it through the "Edit account profile". Thanks for the support!
- schumaku
Glad to help. Can't resist to repeat the word of the wise:FieldNas wrote:Got it! I managed to "disable" it through the "Edit account profile". Thanks for the support!
You had been warned - no more ssh (and telnet) access!
Thanks again for the wise words
This is no longer true on my QTS 4.3 instance. I can SSH into my NAS with my alternate account with "admin" disabled. This does not solve everything, however.schumaku wrote:Glad to help. Can't resist to repeat the word of the wise:FieldNas wrote:Got it! I managed to "disable" it through the "Edit account profile". Thanks for the support!
Many apps have an assumption the "admin" account is still being used within the GUI, even after it is disabled. This is even true of the File Station GUI after Advanced Folder Permissions are turned on in the Shared Folders Control Panel, which references the "admin" account in one of the checkboxes for setting folder permissions.
Also, Linux Station requires the "admin" account to be enabled, and copies it to the linux environment when it is booted for the first time. Without this, you cannot log into the Linux Station instance. This results in a /nas_share folder for this "admin" user which has full access to all directories/shared folders. Also, all other accounts created in QTS will not exist on Linux Station. Any accounts subsequently recreated on the Linux Station OS will need to authenticate with their respective NFS/CIFS accounts to have the appropriate NAS directory permissions; those would be mounted through CIFS and completely separate from the /nas_share folder.
- Don
Topic locked.
