Hi Everyone,
I have a TVS-471; under the App Center > My Apps I can see that I have the Q'center Agent installed. However this same app does not appear on the main Home Screen.
How can I go about adding the Q'center Agent app to the Home Screen for easy access?
Kind Regards,
Davo
Moving App to the Home Screen?
- OneCD
Re: Moving App to the Home Screen?
Hi and welcome to the forum.
At the top-left corner of your QTS desktop, click on the main menu button, find your app, then right-click and select 'Create shortcut'.
Thanks OneCD, your advice worked a treat.
