802.3ad Dynamic Link Aggregation - No Longer An Option
Running TS-453pro and 653pro
After upgrading to 4.3.3.0154, Dynamic (LACP) Link Aggregation is no longer an option when configuring port trunking.
Why was this feature removed?
- schumaku
Re: 802.3ad Dynamic Link Aggregation - No Longer An Option
It's still available of course ... it's "just" the UI design which is sub-optimal, we need to scroll down twice:
And there it is... thanks.
As you've mentioned, it's quite easy to overlook those sliders!
my ts 451 with lacp is not keeping settings once I exit... i thought I have to reboot... still only using eth 1.. Im running plex and copying files from nas to 3 different pc's still using ethernet 1
i have cisco 3750g adv ip services running nothing wrong with my switch or settings (CCNA)
- schumaku
micropone wrote:my ts 451 with lacp is not keeping settings once I exit...
When doing the last step...
... the configuration file (/etc/config/uLinux.conf) is updated ...
[bond0]
Bonding Mode = 4
Configure = TRUE
Use DHCP = TRUE
Usage = DHCP
IP Address = xxx.xxx.xxx.xxx
Subnet Mask = 255.255.0.0
Broadcast = xxx.xxx.255.255
Gateway = xxx.xxx.xxx.xyz
Speed = auto
MTU = 9000
vlan_enable = FALSE
vlan_id = -1
warn of lost for port truking = FALSE
Bonding Member = 1,2
Bonding Index = 1
Hash Policy = 0
What does /proc/net/bonding/bond0 (or /proc/net/bonding/bond1) tell us?
[~] # cat /proc/net/bonding/bond0
Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
Bonding Mode: IEEE 802.3ad Dynamic link aggregation
Transmit Hash Policy: layer2 (0)
What says
[~] # ifconfig bond0
resp.
[~] # ifconfig bond1
"using" - what do you expect exactly?micropone wrote:i thought I have to reboot... still only using eth 1.. Im running plex and copying files from nas to 3 different pc's still using ethernet 1
The NAS does not caremicropone wrote:(CCNA)
Transmit Hash Policy: layer2+3 (2)
MII Status: up
MII Polling Interval (ms): 100
Up Delay (ms): 0
Down Delay (ms): 0
802.3ad info
LACP rate: slow
Min links: 0
Aggregator selection policy (ad_select): stable
System priority: 65535
System MAC address: 00:08:9b:ec:63:11
Active Aggregator Info:
Aggregator ID: 1
Number of ports: 2
Actor Key: 9
Partner Key: 2
Partner Mac Address: 00:22:be:ed:44:00
Slave Interface: eth0
MII Status: up
Speed: 1000 Mbps
Duplex: full
Link Failure Count: 0
Permanent HW addr: 00:08:9b:ec:63:11
Slave queue ID: 0
Aggregator ID: 1
Actor Churn State: none
Partner Churn State: none
Actor Churned Count: 0
Partner Churned Count: 0
details actor lacp pdu:
system priority: 65535
system mac address: 00:08:9b:ec:63:11
port key: 9
port priority: 255
port number: 1
port state: 61
details partner lacp pdu:
system priority: 1
system mac address: 00:22:be:ed:44:01
oper key: 2
port priority: 32768
port number: 262
port state: 61
Slave Interface: eth1
MII Status: up
Speed: 1000 Mbps
Duplex: full
Permanent HW addr: 00:08:9b:ec:63:12
Slave queue ID: 0
Aggregator ID: 1
port key: 9
port priority: 255
port number: 2
port state: 61
system priority: 1
oper key: 2
port number: 263
port state: 61
and
says No such file or directory
MII Status: up
Up Delay (ms): 0
Down Delay (ms): 0
802.3ad info
LACP rate: slow
Min links: 0
Aggregator ID: 1
Number of ports: 2
Actor Key: 9
Partner Key: 2
MII Status: up
Speed: 1000 Mbps
Duplex: full
Slave queue ID: 0
Aggregator ID: 1
port key: 9
port priority: 255
port number: 1
port state: 61
system priority: 1
oper key: 2
port number: 262
port state: 61
MII Status: up
Speed: 1000 Mbps
Duplex: full
Slave queue ID: 0
Aggregator ID: 1
port key: 9
port priority: 255
port number: 2
port state: 61
system priority: 1
oper key: 2
port number: 263
port state: 61
and
and
[~] # cat /etc/network/interfaces
# Configure Loopback
auto lo
iface lo inet loopback
shouldn't bond0 be here?
auto lo
- schumaku
It is perfectly up and running...micropone wrote:[~] # cat /proc/net/bonding/bond0
MII Status: up
Up Delay (ms): 0
Down Delay (ms): 0
802.3ad info
LACP rate: slow
Min links: 0
Aggregator ID: 1
Number of ports: 2
Actor Key: 9
Partner Key: 2
Is the above status taken after finishing the configuration, or before?
No, not at all.micropone wrote:[~] # cat /etc/network/interfaces
auto lo
shouldn't bond0 do here?
LACP rate: slow == how can i change to fast..
computer to nas with 5 gig file win10 system going 30-38 megs ONLY... its not steady how can I fix this issue
thanks in advance
thanks in advance
- schumaku
So what does leave you under the impression that...micropone wrote:after
?micropone wrote:my ts 451 with lacp is not keeping settings once I exit...
As long as the bandwidth of the single channel is sufficient, ...micropone wrote:i thought I have to reboot... still only using eth 1.. Im running plex and copying files from nas to 3 different pc's still using ethernet[
...the other bond members won't be used. The policy on the interface used for sending is on each device.micropone wrote:computer to nas with 5 gig file win10 system going 30-38 megs ONLY...
Why do you want to change this to send the LACP control packets every second vs. the standard 30 seconds? This won't change anything on the possible performance. Blunt theory, there is slightly more overhead (30 times more).micropone wrote:LACP rate: slow == how can i change to fast..
true makes total sense.. I'm in confused and just wondering why files copying so slow.. my plex server has dual nic i can transcode and push 9 steams with no problem cheap i7 build. lacp with an high end cisco switch 3750G-E.. mostly same commands for bonding etc.. i'm order a nas that has 4 gig ports... and try that!!
- Been there, done that
i ditched LACP for 10G ..... there's affordable switches out here that have 2/4 10G ports and 24/48 1G ports. lot easier to manage ......
http://www.balticnetworks.com/mikrotik- ... cages.html
a little more....
https://www.amazon.com/gp/product/B00OZ ... UTF8&psc=1
a little more....
Production :
TVS-673 4.3.4 0387
4 X 3TB WD RED : 1 X 4TB HGST DESKSTAR R5
32GB
LAN-10G1SR-D, FiberHal for Cisco SFP-10G-SR
NETGEAR ProSAFE SS3300-28X
Backup :
TS-469L 4.3.4 0387
4 X 3TB WD RED R5
3GB
Located detached garage .. cheap offsite solution ...
2nd TS-469L awaiting drives and reassignment for front-line duty .......
TVS-673 4.3.4 0387
32GB
Backup :
TS-469L 4.3.4 0387
4 X 3TB WD RED R5
3GB
