Hello.
I've tried to upgrade my Qnap TS-231+ to the latest 4.3.3 version via web interface and it is failing with code fw999.
so i'd tried via ssh with the method described here http://lenjoubertblog.blogspot.co.il/20 ... grade.html
it fails too .
Here's the ssh output :
[~] # ls
index_default.html
[~] # cd ..
[/] # ls /share/Public
/share/Public@
[/] # ls /share/Public/
@Recycle/
[/] # rm -rf /mnt/HDA_ROOT/update/
[/] # mkdir /mnt/HDA_ROOT/update
[/] # ln -sf /mnt/HDA_ROOT/update /mnt/update
[/] # cd share/Public
[/share/Public] # wget https://eu1.qnap.com/Storage/TS-131P_231P_431P_X31+/T>
--2017-05-19 16:10:15-- https://eu1.qnap.com/Storage/TS-131P_23 ... 3.0188.zip
Resolving eu1.qnap.com (eu1.qnap.com)... 80.74.156.130
Connecting to eu1.qnap.com (eu1.qnap.com)|80.74.156.130|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 164527844 (157M) [application/zip]
Saving to: ‘TS-131P_231P_431P_X31+_20170516-4.3.3.0188.zip’
TS-131P_231P_431P_X 100%[===================>] 156.91M 3.97MB/s in 50s
2017-05-19 16:11:05 (3.16 MB/s) - ‘TS-131P_231P_431P_X31+_20170516-4.3.3.0188.zip’ saved [164527844/164527844]
[/share/Public] # unzip TS-131P_231P_431P_X31+_20170516-4.3.3.0188.zip
Archive: TS-131P_231P_431P_X31+_20170516-4.3.3.0188.zip
inflating: TS-131P_231P_431P_X31+_20170516-4.3.3.0188.img
[/share/Public] # cd ~
<ublic/TS-131P_231P_431P_X31+_20170516-4.3.3.0188-work.img
<Public/TS-131P_231P_431P_X31+_20170516-4.3.3.0188-work.img
cksum=3359306807
UBI device number 1, total 1728 LEBs (219414528 bytes, 209.2 MiB), available 1720 LEBs (218398720 bytes, 208.3 MiB), LEB size 126976 bytes (124.0 KiB)
Set volume size to 218398720
Volume ID 0, size 1720 LEBs (218398720 bytes, 208.3 MiB), LEB size 126976 bytes (124.0 KiB), dynamic, name "tmp", alignment 1
Using 120-bit encryption - (QNAPNASVERSION4)
len=1048576
model name = TS-X41
version = 4.3.3
IS_STORAGE_V2
boot/
config/
fw_info
fw_info.conf
libcrypto.so.1.0.0
libssl.so.1.0.0
rootfs2.ubi
rootfs2.ubi.cksum
uImage
uImage.cksum
update/
update_img.sh
4.3.3 20170516
MODEL NAME = TS-X41,new version = 4.3.3
limit version = 3.7.2
Allow upgrade
Allow upgrade
2017-05-19 16:18:10 Check CRC
2017-05-19 16:18:10 cksum: uImage ...ok
2017-05-19 16:18:11 cksum: rootfs2.ubi ...ok
2017-05-19 16:18:11 Update uImage(Kernel + initrd.boot) to Recovery Partition
2017-05-19 16:18:11 erase nand (mtd4)
2017-05-19 16:18:12 write nand (mtd4)
2017-05-19 16:18:17 Update rootfs2.ubi
2017-05-19 16:18:17 write nand (mtd5)
2017-05-19 16:19:04 Update uImage(Kernel + initrd.boot) to Main Partition
2017-05-19 16:19:04 erase nand (mtd2)
2017-05-19 16:19:04 write nand (mtd2)
2017-05-19 16:19:07 mtd2 write failed, retry. (Error)
2017-05-19 16:19:09 mtd2 write failed. (Fatal Error)
[Firmware Update] System update failed. Error code: FW999
What should i do next
Please help.
TS 231+ upgrade from 4.2.5 to 4.3.3 problem
Re: TS 231+ upgrade from 4.2.5 to 4.3.3 problem
Update , the same process with 4.2.5 firmware works fine , tried again with 4.3.3 firm ware - the problem returns..
logs for the 4.2.5 upgrade :
[~] # /rm -rf /mnt/HDA_ROOT/update/
-sh: /rm: No such file or directory
[~] # rm -rf /mnt/HDA_ROOT/update/
[~] # rm -rf /mnt/update
[~] # mkdir /mnt/HDA_ROOT/update
[~] # ln -sf /mnt/HDA_ROOT/update /mnt/update
<231P_431P_X31+/TS-131P_231P_431P_X31+_20170413-4.2.5.zip
--2017-05-19 20:38:56-- https://download.qnap.com/Storage/TS-13 ... -4.2.5.zip
Resolving download.qnap.com (download.qnap.com)... 104.79.231.27, 2a02c000:184::1b52, 2a02c000:183::1b52
Connecting to download.qnap.com (download.qnap.com)|104.79.231.27|:443... connected.
Length: 172252817 (164M) [application/zip]
Saving to: ‘TS-131P_231P_431P_X31+_20170413-4.2.5.zip’
TS-131P_231P_431P_X 100%[===================>] 164.27M 3.37MB/s in 49s
2017-05-19 20:39:50 (3.36 MB/s) - ‘TS-131P_231P_431P_X31+_20170413-4.2.5.zip’ saved [172252817/172252817]
[~] # ls
index_default.html
[~] # mov TS-131P_231P_431P_X31+_20170413-4.2.5.zip /share/Public/
-sh: mov: command not found
[~] # mv TS-131P_231P_431P_X31+_20170413-4.2.5.zip /share/Public
[~] # ls
index_default.html
[~] # cd /share/Public
[/share/Public] # ls
@Recycle/
[/share/Public] # unzip TS-131P_231P_431P_X31+_20170413-4.2.5.zip
Archive: TS-131P_231P_431P_X31+_20170413-4.2.5.zip
inflating: TS-131P_231P_431P_X31+_20170413-4.2.5.img
[/share/Public] # rm TS-131P_231P_431P_X31+_20170413-4.2.5.zip
<Public/TS-131P_231P_431P_X31+_20170413-4.2.5-work.img
[~] # ls
index_default.html
[~] # ls /share/Public/
@Recycle/
<hare/Public/TS-131P_231P_431P_X31+_20170413-4.2.5-work.img
cksum=784807495
len=1048576
model name = TS-X41
version = 4.2.5
IS_STORAGE_V2
boot/
config/
fw_info
libcrypto.so.1.0.0
libssl.so.1.0.0
rootfs2.ubi
rootfs2.ubi.cksum
uImage
uImage.cksum
update/
update_img.sh
4.2.5 20170413
MODEL NAME = TS-X41,new version = 4.2.5
Allow upgrade
Allow upgrade
2017-05-19 20:42:57 Check CRC
2017-05-19 20:42:57 cksum: uImage ...ok
2017-05-19 20:42:59 cksum: rootfs2.ubi ...ok
2017-05-19 20:42:59 Update uImage(Kernel + initrd.boot) to Recovery Partition
2017-05-19 20:42:59 erase nand (mtd4)
2017-05-19 20:42:59 write nand (mtd4)
2017-05-19 20:43:04 Update rootfs2.ubi
2017-05-19 20:43:04 write nand (mtd5)
2017-05-19 20:43:54 Update uImage(Kernel + initrd.boot) to Main Partition
2017-05-19 20:43:54 erase nand (mtd2)
2017-05-19 20:43:54 write nand (mtd2)
2017-05-19 20:43:59 Update Rootfs2.ubi
2017-05-19 20:43:59 write nand (mtd3)
2017-05-19 20:44:49 Update Finished
/share/CACHEDEV1_DATA
set cksum [784807495]
logs for 4.3.3 upgrade again
[/share/Public] #
@Recycle/
<S-131P_231P_431P_X31+/TS-131P_231P_431P_X31+_20170413-4.3.3.0154.zip
--2017-05-19 20:29:08-- https://eu1.qnap.com/Storage/TS-131P_23 ... 3.0154.zip
Length: 164427487 (157M) [application/zip]
Saving to: ‘TS-131P_231P_431P_X31+_20170413-4.3.3.0154.zip’
TS-131P_231P_431P_X 100%[===================>] 156.81M 2.42MB/s in 53s
2017-05-19 20:30:07 (2.95 MB/s) - ‘TS-131P_231P_431P_X31+_20170413-4.3.3.0154.zip’ saved [164427487/164427487]
[/share/Public] # unzip TS-131P_231P_431P_X31+_20170413-4.3.3.0154.zip
Archive: TS-131P_231P_431P_X31+_20170413-4.3.3.0154.zip
inflating: TS-131P_231P_431P_X31+_20170413-4.3.3.0154.img
[/share/Public] # rm TS-131P_231P_431P_X31+_20170413-4.3.3.0154.zip
@Recycle/
<c/TS-131P_231P_431P_X31+_20170413-4.3.3.0154.img
cksum=280375758
len=1048576
model name = TS-X41
version = 4.3.3
IS_STORAGE_V2
boot/
config/
fw_info
fw_info.conf
libcrypto.so.1.0.0
libssl.so.1.0.0
rootfs2.ubi
rootfs2.ubi.cksum
uImage
uImage.cksum
update/
update_img.sh
4.3.3 20170413
Allow upgrade
Allow upgrade
2017-05-19 20:33:31 Check CRC
2017-05-19 20:33:31 cksum: uImage ...ok
2017-05-19 20:33:33 cksum: rootfs2.ubi ...ok
2017-05-19 20:33:33 Update uImage(Kernel + initrd.boot) to Recovery Partition
2017-05-19 20:33:33 erase nand (mtd4)
2017-05-19 20:33:33 write nand (mtd4)
2017-05-19 20:33:38 Update rootfs2.ubi
2017-05-19 20:33:38 write nand (mtd5)
2017-05-19 20:34:26 Update uImage(Kernel + initrd.boot) to Main Partition
2017-05-19 20:34:26 erase nand (mtd2)
2017-05-19 20:34:26 write nand (mtd2)
2017-05-19 20:34:29 mtd2 write failed, retry. (Error)
2017-05-19 20:34:31 mtd2 write failed. (Fatal Error)
any advice?
[~] # ls
index_default.html
[~] # ls
index_default.html
@Recycle/
[~] # ls
index_default.html
@Recycle/
cksum=784807495
len=1048576
model name = TS-X41
version = 4.2.5
IS_STORAGE_V2
boot/
config/
fw_info
libcrypto.so.1.0.0
libssl.so.1.0.0
rootfs2.ubi
rootfs2.ubi.cksum
uImage
uImage.cksum
update/
update_img.sh
4.2.5 20170413
Allow upgrade
Allow upgrade
[/share/Public] #
@Recycle/
@Recycle/
cksum=280375758
len=1048576
model name = TS-X41
version = 4.3.3
IS_STORAGE_V2
boot/
config/
fw_info
fw_info.conf
libcrypto.so.1.0.0
libssl.so.1.0.0
rootfs2.ubi
rootfs2.ubi.cksum
uImage
uImage.cksum
update/
update_img.sh
4.3.3 20170413
Allow upgrade
Allow upgrade
any advice?
- schumaku
Please get in touch with the QNAP Customer Service on https://helpdesk.qnap.com/
Edit: As per QNAP Customer Service rep, the NAS has be sent for repair.
-Kurt
-Kurt
