My old TS 251 broke and I just received a new unit of the same model.
As a test, I inserted only one drive (it had been set up as RAID1), during the boot it found a previous Qnap installation on the HD.
I chose the option to keep existing files. The unit now boots up. When I check the drive space, it correctly shows that about 60% is used.
However, I don't see any of my folders files. Should I insert the second drive? Any help is appreciated. Thanks in advance.
Reusing Hard Drives from other TS 251
- Don
Re: Reusing Hard Drives from other TS 251
Follow the procedure in the manual for moving drivwa from one unit to another.
Thanks Don. I am afraid that it was a mistake to put back only one drive. It wasn't easy to find how to migrate the drive without your pointer. Based on the information, both drives should be inserted. I guess, I'll have to create a ticket now.
- schumaku
In general, the drives can be moved straight away. Even a "half" RAID1. The point is that something could have been broken on the config while the old TS-251 broke down.
I was able to get my folders back with Qnap's help. It turns out, all you have to do is go to Control Panel->Shared folders. : create a new share. Instead of "Specify path automatically" selected, select "Enter path manually" and find the folder of the share you want to create.
- schumaku
Great, thank you for the update!eleonora01 wrote:I was able to get my folders back with Qnap's help.
Moving the HDD from one to another QNAP NAS does move the configuration data (including users, groups, shared folders [default and user defined ones], ...) to the new NAS. Hard to say what happened over time with this config - potentially someone tried a reset to fix the old NAS before?eleonora01 wrote:It turns out, All you have to do is go to Control Panel->Shared folders. : create a new share. Instead of "Specify path automatically" selected, select "Enter path manually" and find the folder of the share you want to create.
