How to change the port or URL of a shortcut
For security reason, I would like to change the port of PLEX server to an custom one instead of standard one. But I cannot access PLEX webpage directly after port change, is it possible to change URL port of PLEX shortcut manually? Thank you
Re: How to change the port or URL of a shortcut
if you want to access plex from the wan (bad idea) just change the forwarding port on the router
not sure what "shortcut" you are talking about
I mean the PLEX icon in QNAP web interface
can you manually change the port in the browser (to the one you changed it to)
if so .. just bookmark the new webgui port and that's it
