- Qnap TS-219P
- Firmware version and Build Number Unable to establish as it won't appear in Finder, however I believe I recently updated to the same build as 469P which is 4.3.3-20170901
- Windows 7 Home Premium SP1 64Bit
- OS Language - English
- Number of HDDs - 2
- HDD model - Western Digital Red WD30EFRX
- HDD capacity - 3.0TB
- RAID configuration - I believe the two bays were set up in a mirror configuration
- Services enabled, e.g. Download Station, DDNS, FTP, NFS - can no longer establish as cannot access the device
- External devices, e.g. USB printer, e-SATA drive - unknown, nothing was/is connected to the device other than an Ethernet cable
- NAS connection speed/ MTU (found in Network Settings>TCP/IP page)
I have had a 219P for many years and eventually upgraded to a 469 Pro. After also upgrading the HDD's to 3.0TB WD Reds (WD30EFRX) I passed the 219P on to my parents and copied all their digital photos from their various lap tops and thumb drives onto the bays. It sat there on their network doing very little for some time. I ended up also hooking up my 469 to their network and together both were operational over the internet.
Perhaps a year ago they upgraded their internet and had installers come out to change over the ADSL modem to the (Australia's) 'National Broadband Network'. The installers decided to just disconnect the devices and leave them sitting in a box. So recently I tried hooking them both back up and struggled to see the devices over the LAN. So I hooked up an Ethernet hub directly to my PC. I managed to see both devices briefly but not necessarily at the same time, using QFinder etc.
Out of frustration in trying to view the contents through the 'Çomputer' portion of Explorer, I think I accidentally clicked on Configure when viewing the 219P through FInder, which I subsequently realised was a faux pas. Turning it on now it just goes to the flashing red/green light and does not appear in QFinder. I tried plugging each bay individually into an external HDD enclosure to see if I could just read the data off onto another spare drive then start from scratch again, but they cannot be read. They show up in Explorer as about 4 different virtual bays and all say they need to be formatted. This is probably obvious why to many of you but not to me.
Anyway I'm trying to figure out where to start in terms of things to try in order to recover any photos and videos on there.
Thanks in advance and apologies that I don't have much information available.
PS - I don't recall there being any stringent warnings about wiping the content of the drives by clicking on Configure (someone may be able to clarify because it's too late to check now). At best it may have said the process cannot be undone but I'm pretty sure it didn't say the contents would be cleared (because I'm stupid but don't believe I'm that stupid!). If so then there should be more fail safes or greater clarity associated with that button.
Michael
