I recently update my firmware(around end of October 2017), and my device (TS-212E) starts disconnecting.
After I updated to the newest firmware, I was not able to connect to my device while all lights show normal.
Then I manually re-boot my device, I was able to connect to my device for a while (1-2 hours). After that, I cannot connect to my device.
Every time I manually re-boot my device, something happens.
Does anyone know what is going on? How can I fix it?
Disconnecting
Re: Disconnecting
seems like the same issue a lot of old kirkwood users have, no solution so far (lots of threads about it)
going back to 4.2.x seems to help
Re: Disconnecting
How do I go back to 4.2?dolbyman wrote:seems like the same issue a lot of old kirkwood users have, no solution so far (lots of threads about it)
Re: Disconnecting
download the 4.2.x firmware from the qnap website and manually update(downgrade) it
Re: Disconnecting
downgrade to 4.2.5, still having the same problem.
