upgraded from a ts-253a which i now regret.
this device is so loud, any way of reducing the amout of noise this device makes
in the ts-253a it was quieter.
thanks
ts-253b - latest firmware 4.4.1.1146 - 2 x 14 wd red (raid 1) . - ISSUE of noise?
Re: ts-253b - latest firmware 4.4.1.1146 - 2 x 14 wd red (raid 1) . - ISSUE of noise?
put it on a foam mat or into a cabinet
or just another room where it wont bother you
- Been there, done that
You should have upgraded to a 4 bay unit which has a larger 120mm fan and doesn't have to spin as fast.kyrusdemnati wrote: ↑Sun Jan 12, 2020 5:12 am upgraded from a ts-253a which i now regret.
thanks
