My QNAP TS-453mini was shutdown for a long time (several months).
I wanted to start using it again but it doesn't boot any more...
Nothing appears on the TV, connected via HDMI.
Nothing is discovered by Qfinder Pro.
I tried the "reset" procedure several times. It didn't solve a thing.
I finally decided to open it and remove SATA disks, RAM, battery and internal storage.
On power on, there still is nothing on the screen. And no bips.
Only the blue front light and ethernet blinking orange.
Any ideas about other things to try ?
Any chance the MB is not simply dead ?
Thank you.
QNAP TS-453mini not booting anymore
Re: QNAP TS-453mini not booting anymore
what reset procedure are you talking about ?
