Why is volume capacity less than drive capacity?
Discussion on setting up QNAP NAS products.
grouillier
Post by grouillier »
I found this posting via Google. I hope I'm not breaking any rules by resurrecting this thread.
I just got a TS-230, and put in a single 750 GB drive I already had. I will eventually get some larger drives.
I'm seeing this same issue as the OP. Since I only have a single drive, I went with a static volume. On the volume management page, I see:
Raid Group 1 Capacity 689 GB (created automatically, I did not create this)
NAS Host: Disk 1 Capacity 698 GB
Volume Capacity 638 GB
Where has the other 50-60 GB gone? From what I'm reading here, QNAP will store any necessary system files within the allocated volume space. In other words, there should be no hidden volume that QNAP has reserved for its own use.
Thanks.
TS-230, TS-253A, both with latest stable QTS
OneCD
Re: Why is volume capacity less than drive capacity?
Post by OneCD »
* topic split from viewtopic.php?f=11&t=147094 *
Hi and welcome to the forum. :)
Let's start with your mounted block-device sizes. What is shown if you run 'df'?
df
... and should probably check the partitions on your new drive too:
parted /dev/sda print
Return to “Turbo Station Installation & Setup”
