How to disable admin account/user?
Discussion on setting up QNAP NAS products.
twiga
Post by twiga »
Apologies if this is not he correct forum topic to post in.
I have received a number of failed attempts to access my NAS. I have 2FA in place, but am still nervous.
I have read up on this issue, and many advise to isable default admin account and create a new administrator account; however edit account profile the check box to disable admin account is 'greyed' out?
Any help appreciated. :-)
Many thanks
Model: TS-453 Pro + TS-653 Pro
Mousetick
Experience counts
Re: How to disable admin account/user?
Post by Mousetick »
Before asking any FAQ on a forum, you should always search online, because it's extremely likely you'll find the answer you're looking for, and as a bonus you'll be saving precious time, both yours and the people's who are kind enough to answer those same questions asked again and again and again.
Google "qnap disable admin account"
4th result is: QNAP Support: How to disable the ''admin'' user account?
Toxic17
Ask me anything
Contact:
Post by Toxic17 »
also stop allowing access to your NAS from the internet!
Regards Simon
Qnap Downloads
MyQNap.Org Repository
QNAPDanielFL
Easy as a breeze
Post by QNAPDanielFL »
Something the protects better than disabling admin is to un-forward ports and make sure there is no UPnP.
Something very easy is to use Qlink for remote access without any port forwarding. It does need the NAS to be registered with myqnapcloud. So I would make that password the kind you can't remember, but your browser remembers for you and you write down in case your browser forgets. You don't need to use all the myqnapcloud services, and you can turn off all the services that can be turned off except qlink. https://www.qnap.com/solution/myqnapcloud-link/en-us/
VPN is even better. But requires a little more setup. You need to forward just 1 VPN port. And set up the connection with each device you want to have remote access.
Either of these 2 methods should be much safer than port forwarding. You can disable admin as well. But the main protection is not forwarding ports.
twiga
Post by twiga »
Mousetick wrote: Sun Apr 25, 2021 3:38 am Before asking any FAQ on a forum, you should always search online, because it's extremely likely you'll find the answer you're looking for, and as a bonus you'll be saving precious time, both yours and the people's who are kind enough to answer those same questions asked again and again and again.
My apologies, I forgot to mention ... I have already done this. i.e., created a new user, and allocated admin privileges and assigned to administrators group .... but still the check box for disable this account for ADMIN user is greyed out.
twiga
Post by twiga »
QNAPDanielFL wrote: Mon Apr 26, 2021 5:13 am Something the protects better than disabling admin is to un-forward ports and make sure there is no UPnP.
Thanks - very helpful. :-) I know where to uncheck UPnP - but how do I know if I have any port forwarding? :-)
My NAS is registered with myqnapcloud - so have that all set up. :-)
Can you tell me more about how to set up VPN on NAS? I have this at PC level, but not NAS level.
QNAPDanielFL
Easy as a breeze
https://www.qnap.com/en-us/how-to/tutor ... d-use-qvpn
That is how to use QVPN. And of course, you can use other VPN options as well.
You can log on your router and find port forwarding information. Different routers have different layouts so I may not be able to tell you exactly how to navigate to Prot Forwarding on your particular router. But I suspect it won't take too long to find.
twiga
Post by twiga »
QNAPDanielFL wrote: Mon Apr 26, 2021 8:31 am https://www.qnap.com/en-us/how-to/tutor ... d-use-qvpn
Thank you. No port forwarding on my router. Will look into the VPN set-up. :-)
Moogle Stiltzkin
Contact:
Post by Moogle Stiltzkin »
twiga wrote: Mon Apr 26, 2021 8:54 am Thank you. No port forwarding on my router. Will look into the VPN set-up. :-)
https://www.reddit.com/r/qnap/comments/ ... _from_the/
recommended to use the vpn server method (using openvpn)
https://www.youtube.com/watch?v=PgielyUFGeQ
NAS
Network
Resources
Mousetick
Experience counts
Post by Mousetick »
twiga wrote: Mon Apr 26, 2021 8:11 am My apologies, I forgot to mention ... I have already done this. i.e., created a new user, and allocated admin privileges and assigned to administrators group .... but still the check box for disable this account for ADMIN user is greyed out.
No you didn't. You didn't follow the procedure given by the help page I linked to. Or you didn't follow the steps in the correct order.
I'll give you a hint: a user cannot disable their own account.
Return to “Turbo Station Installation & Setup”
