TS-453A ethernet network inaccessible
Discussion on setting up QNAP NAS products.
Marcraft
First post
Post by Marcraft »
Hello
I was working in "virtualization station3" with a Centos 7 virtual machine. I have two ethernet ports connected between the NAS and my local router, in the "Network & Virtual Switch" I have-
  • The Virtual switch 1 connected to the network adapter1 (local connection)
  • The virtual switch 2 connected to the network adapter 2 (connection for virtual machines)
After several unsuccessful attempts to have internet in Centos virtual machine through Virtual switch 2, I tried to add the Virtual Switch2 to my network adapter1, the NAS network was restarted and from this, the ping responds as inaccessible, I can't enter by http, ssh, qnapcloud, etc.
Before configuration:
  • Network adapter1 IP: 192.168.0.100 (virtual switch 1 same ip)
  • Network adapter2 IP: 192.168.0.50 (virtual switch 2 same ip)
After configuration:
  • IP adapter1: No http, ssh, myqnapcloud, etc ping response inaccessible, 0 pacakage lost
  • IP adapter2: No http, ssh, myqnapcloud, etc ping all pacakage lost
(see attachment ping inaccesible)
  • My model TS-453A does not have a quickaccess port
  • Qfinderpro finds the QNAP with the IP 192.168.0.50 in both adapters (currently no ping), I access in the configuration and the adapter 1 and 2 have the same configuration,with wrong gateway, my real gateway is 192.168.0.1, I tried change this, but after the confirmation, I access in configuration againg and the wrong configuration continuos the same
(see attachment wring gateway)
  • I tried pressing the reset button for 3 seconds but after this nothing happens, everything continues the same (probably this option was not active in the qnap)
I don't want to lose my data inside the qnap, I already restarted it several times, I tried to connect 1 ethernet port, testing the 4 ports and searching for it by qfinderpro via DHCP but I was not successful either, I just don't know what what can I do
Does anyone have any other suggestions? Thanks
elvisimprsntr
Re: TS-453A ethernet network inaccessible
Post by elvisimprsntr »
Can you connect up a monitor/KB and get to a console interface to reset the virtual network switch?
https://www.qnap.com/en/how-to/knowledg ... mmand-line
I had a situation where the TS-453A stopped responding on all Ethernet interfaces. Solution was to depower, unplug power, press start button too discharge any standby power, plug in power, and power backup.
Return to “Turbo Station Installation & Setup”
