Brand new TS-131P, stuck in installation loop
Discussion on setting up QNAP NAS products.
Locked
jlkl100
First post
Post by jlkl100 »
I've got the same problem. Can not reach the login page after installation is completed. Once I click Go To Nas Management icon the installation window appears again and so the whole process. The disk diod on the ts-230 lights red. I do not have any idea how to check if the drive (Seagate Ironwolf 4TB) is working properly or not. I do not have any other NAS drive to replace it.
Could you please help ?
OneCD
Re: Brand new TS-131P, stuck in installation loop
Post by OneCD »
* topic split from viewtopic.php?f=11&t=150011 *
dolbyman
Post by dolbyman »
Make sure the new disk is completely formatted (clean) before you start the installation
Then try again
Locked
Return to “Turbo Station Installation & Setup”
