TS-453Be - Memory Upgrade & Now No LED's or operation - Help, depressed!
Discussion on setting up QNAP NAS products.
atacama40
Post by atacama40 »
Evening all, after years of waiting I got a 453Be last Summer & added 3 drives. Live been complex since and unit has been on and running but not really used.
Went to upgrade my 2gb to 8gb today thinking it would be straightforward.
Fitted the memory (new Crucial branded) rebooted and no LED's on the front panel. Fan goes round at the back and the 10Gb card has green LEDS on.
So power is getting there but but no boot as such. Qfinder does not see it either, only my old 410 that was to be migrated from.
Any ideas guys? Can see no loose leads or suchlike.
I have tried refit the original memory stick but no joy.
Waited years to be able get this unit and not got a clue were to start with fault finding. What a pain.
Many thanks in advance.
dolbyman
Re: TS-453Be - Memory Upgrade & Now No LED's or operation - Help, depressed!
Post by dolbyman »
Did you ground yourself properly ? .. You might have fallen victim to ESD
https://en.wikipedia.org/wiki/Electrostatic_discharge
Open a ticket with QNAP and maybe omit your RAM 'stunt' so they won't refuse warranty
atacama40
Post by atacama40 »
dolbyman wrote: Thu May 06, 2021 2:01 am Did you ground yourself properly ? .. You might have fallen victim to ESD
I have to say dolbyman I didn't no. Blimey I wander. Got away with that on laptops and desktops etc forever ...... wander if lack of prep finally caught up with me.Arghhh.
Thanks for the steer, have to say that does make sense. I'm going out to get pizza and wine to drown my sorrows !!!!!
elvisimprsntr
Post by elvisimprsntr »
Did you get the correct DDR3L-1600 RAM?
https://www.crucial.com/compatible-upgr ... AP/ts-453b
Did you buy RAM from reputable source to avoid counterfeit RAM?
We’re you installing two 4gb sticks or one 8gb stick? Specs are two 4gb sticks.
atacama40
Post by atacama40 »
Yes that's the modules Elvis, two 4GB's and exactly the spec on the link.
They have been sitting here a while but in the normal memory plastic cartons and well wrapped.
I did wander if they were good but when the old unit replaced, still the same problem
Return to “Turbo Station Installation & Setup”
