IP Access Protection don't work
Hello.
Due business reasons and some user limitation I was forced to expose my TS-231P with QTS 4.5.3.1652 to Internet via port-forwarding of standard Samba ports on my firewall. I know the rules about 'no Internet to NAS', but I mitigate this by all available ways.
Of course, sometimes cool hackers scans WAN and, once discover opened Samba-ports, trying to brute password to some 'default' accounts that doesn't exists:
Why QTS doesn't react to this even with correct IP / Account access protection?
I suppose that Account protections doesn't work because that is attempts to logon into non existing account, but why QTS don't ban those IPs due more that 5 failed login attempts in 30 mins?
Re: IP Access Protection don't work
Also I've noticed that there is some successfull logon events of 'guest' via SMB:
But:
- there is no 'guest' account in the system
- guest access is denied to every share I have on QNAP
- every share have ABE / ABSE is enabled
- consequently anonymous users are restricted from accessing SMB shared folders at all
- advanced folder permission is enabled too
So if there is some way to logon with 'guest' it won't give access to any share or file. By the way, I tried to simulate this situation by trying to log on from Windows / macOS via SMB with guest / guest or just with 'guest' and no password or without specifying any credentials at all, using different SMB version, with GUI or cli but I didn't get even closer to such event on my QNAP (successful guest login). So I don't understand how it can be possible and I suppose that there is some incorrect logging process that tells me about successfull guest login while it was not happened. Am I right or just missing something?
But:
- jaysona
- Been there, done that
You will have to ask QNAP why the settings are not working. Also, there is no reason to blank out the IP addresses of the source IP addresses, in fact those IP addresses may help some that keep track of bot-net IP addresses.
Also, 30 minutes is too generous for Internet exposed systems, you should set it to the lowest possible. I have asked QNAP to add 1-minute as the minimum, no such luck - yet.
RAID is not a Back-up!
H/W: QNAP TVS-872x (i7-8700. 64GB) (Plex server & encoding host) / TVS-EC1080 (32Gig ECC) - VM host & seedbox
H/W: Asustor AS6706T (32GB) / Asustor AS7010T (16GB) (media storage)
H/W: TS-219 Pro / TS-509 Pro
Router1: Asus RT-AX86U - Asuswrt-Merlin - 3004.388.6_2
Router2: Asus RT-AC66U - Asuswrt-Merlin - 386.12_6
- jaysona
Welcome to the world of QNAP and its insecure QTS operating environment. Maybe someone found yet another QTS vulnerability that can be exploited, maybe it is false positive log entry - only QNAP will be able to tell you for certain.
I'm already have huge amount of subnets where infected machines (or real hazkers) constantly scanning network (and my QNAP) but what next? I can't provide this info to anyone (guess that even theirs ISP won't block them or smth else) and I'm not interested in further investigation so for now I'm just ban whole subnets like XX.XXX.XXX.0\24 via QuFirewall until I will deal with automatic IP Access Protection.there is no reason to blank out the IP addresses of the source IP addresses, in fact those IP addresses may help some that keep track of bot-net IP addresses
Why? Some 'scanners' not so stupid so they take some pause between retries. In this case 30 min period to monitor will discover and ban them more efficienly than short period like 1 min.30 minutes is too generous for Internet exposed systems, you should set it to the lowest possible
Okay, will try my luck with official support.You will have to ask QNAP why the settings are not working
- Easy as a breeze
venique wrote: ↑Mon May 10, 2021 11:36 pm Hello.
You ask a good question. I was just told we will add a new feature to ban IPs due to more than 5 failed login attempts in 30 min even if it is for a non-existing account.
- Easy as a breeze
Would it be possible to make a support ticket so we can investigate what you are experiencing? And if I know the ticket number, I can pass it on to our our PSIRT team.venique wrote: ↑Mon May 10, 2021 11:51 pm Also I've noticed that there is some successfull logon events of 'guest' via SMB:
But:
So for now IP Access Protection works only for valid accounts, that's the reason, right? If somebody trying to brute force some non-existing account, their IP wouldn't be banned? How quick new function will be released?QNAPDanielFL wrote: ↑Wed May 12, 2021 9:43 am You ask a good question. I was just told we will add a new feature to ban IPs due to more than 5 failed login attempts in 30 min even if it is for a non-existing account.
I'm glad to hear such feedback, but there is some difficults.QNAPDanielFL wrote: ↑Wed May 12, 2021 9:47 am Would it be possible to make a support ticket so we can investigate what you are experiencing? And if I know the ticket number, I can pass it on to our our PSIRT team.
Actually, I have QNAP D2 which is copy of TS-231P (identical HW/FW, just other model name) and supplied to RU region. So Global Support are not eager to deal with my tickets and asking me to search help with Russian Helpdesk. They, in turn, can't know everything so just creating tickets to HQ as their own instead of me. Similar situation happened this time. And now HQ asking me to provide them Remote Support to figure out what is going on.
Before that, of course, I decided to encrypt my data but realised that there is no such option. Our helpdesk answers that any encryption is disabled on hardware level due Customs Union regulations. If I wish - I can use any 3-rd party software for encryption purposes (which one?) without any warranty of data loss. If I don't - I can provide Remote Support with access to all my personall and security-sensitive data 'as is'.
So I don't know how to deal with that burrocraty. May be HQ can connect via TeamViewer so I can monitor their activity?
- Easy as a breeze
If I have the ticket number I can ask what we can do.venique wrote: ↑Wed May 12, 2021 7:46 pmI'm glad to hear such feedback, but there is some difficults.QNAPDanielFL wrote: ↑Wed May 12, 2021 9:47 am Would it be possible to make a support ticket so we can investigate what you are experiencing? And if I know the ticket number, I can pass it on to our our PSIRT team.
Unfortunately, I'm not able to use PM to send you ticket number in private, maybe you have any other method I can reach you by?
- Easy as a breeze
danielfrancislyon@qnap.com
Sent. Thank you in advance!
