I bought a new TS-253D and equiped it with two 4TB Seagate Ironwolf in a RAID1 configuration. I also upgraded to the latest firmware 4.5.3
At first install, a few default shared folders should be created, such as "Public", "Download", "Multimedia", "Web" and "homes".
But on my 253D only "Public" and "homes" seem to exist. (checked via ControlPanel > Privilege > Shared Folders)
To be sure, I completely reinitialized the 253D but the result is the same.
Is there something wrong or has Qnap's policy changed?
Default shared folders missing?
Re: Default shared folders missing?
just create the default ones via the button in the share management
I could do that, but I am a bit worried that the lack of the default folders might be an indication that something is wrong with this station. The manual still says that that are created on install.
normally they are ..maybe you opted to not create a volume on install? you need to have a system volume in order to create the default shares
- OneCD
This is normal. Recent firmwares have reduced the number of default shares.toeternietoe wrote: ↑Mon May 24, 2021 7:53 pm But on my 253D only "Public" and "homes" seem to exist. (checked via ControlPanel > Privilege > Shared Folders)
So it seems.OneCD wrote: ↑Tue May 25, 2021 4:33 amThis is normal. Recent firmwares have reduced the number of default shares.toeternietoe wrote: ↑Mon May 24, 2021 7:53 pm But on my 253D only "Public" and "homes" seem to exist. (checked via ControlPanel > Privilege > Shared Folders)
In the meantime I discovered a small but significant difference between the Dutch version of the manual I had been reading and the latest English version. The English version - but only with regard to the "Web" folder - says: "You must enable Web Server automatically to create this default shared folder". I did and the folder appeared. I tried the same approach for the other missing folders and activated the Multimedia Console and the Download Station. Guess what? The missing folders appeared also.
So all this seems to be expected behaviour. By Qnap that is, not by me. Perhaps they could mention it in their manuals? I would certainly avoid a lot of lost time and confusion.
