Hello
As in the title. I have fairly good knowledge of PC hardware, apparently lmuch ess about networking and obviously (to me) nothing about NAS.
I am hoping to run the NAS only through the 2.5GBe card (QXG-2G1T-I225) and disconnect the 1GBe cable from the default interface. The NAS appears to see both adapters (and I have set the 2.5GBe one as the default gateway for internet access) but if I disconnect the cable to the 1GBe adapter I lose connection to the NAS on my network.
Have searched this forum and any manuals I can find from QNAP's site but I must be missing something.
Can this be done?
KS
Added 2.5GBe Expansion Card to TS-251D
Re: Added 2.5GBe Expansion Card to TS-251D
the 2.5 GbE interface probably has a different IP .. so if you access the NAS via IP, adapt it in your clients.
Thank you for the speedy response.
It does have a different static IP address. Most of the clients are WIndows 10 but I cannot get them to see the NAS on the network if the 1GBe adapter is disconnected -even specifying the different IP address.
More Googling required!
- qrusher
fw update required
crush qnaps like a thanos crushing planets
Updates are compromise between old bug patches and new bugs introduced.
do you backup..then kill it with fire
stuff:mikrotik Crs309-1g-8s+in & s+rj10 x4
