Locked up after Firmware Upgrade to 5.0.0.1716(20210701)
Discussion on setting up QNAP NAS products.
Scubapelli
Post by Scubapelli »
TS-453be
Did a firmware upgrade this morning. System rebooted but after about 30 minutes I was unable to access it. Drive lights are flashing as if working; however, the status light is RED and there is no LAN light. I hooked up a monitor directly to the NAS and it seems to be stuck on "Starting..." I did a power reset but ended up with the same results. I have a trouble ticket submitted with QNAP.
Scubapelli
Re: Locked up after Firmware Upgrade to 5.0.0.1716(20210701)
I let the server run for about an hour and it eventually came back online. Must have been a drive issue it was correcting.
Trexx
Ask me anything
Post by Trexx »
Could be usb external drive issue if you have any attached.
Paul
UPS: CP AVR1350
Return to “Turbo Station Installation & Setup”
