TVS-H1688X setup
Discussion on setting up QNAP NAS products.
rylim
TVS-H1688X setup
Post by rylim »
Hello All,
I just bought a TVS-H1688X and totally new to Qnap NAS, and would like to seek help for following matters:
1) I have plugged in a 16TB HDD that contains files, and the NAS doesn't allow me to read the files inside the drive.
2) The volume setting doesn't have any JBOD option and is it hidden?
3) Which type of RAID allows me to expand the capacity in the future without erasing the volume?
Will really appreciate if anyone can help me out on this.
OneCD
Re: TVS-H1688X setup
Post by OneCD »
* topic split from viewtopic.php?f=12&t=157042 *
dolbyman
Post by dolbyman »
just replied to the other thread
1) dont..it will delete your drive and data on it
2)you can go with single drives..just not with data intact
3) ZFS will not work for that .. so if you want to add disks later go with qts and regular mdraid
rylim
Post by rylim »
dolbyman wrote: Sat Sep 25, 2021 2:08 pm just replied to the other thread
Appreciate for your reply.
It seems like there is no way to retain the data inside the drive at all or read the data inside the HDD thru the NAS, right?
dolbyman
Post by dolbyman »
no..but depending on how they are formatted..you can externally attach them via usb dock to the nas
Bob Zelin
Experience counts
Contact:
Post by Bob Zelin »
I would never have spent $3100 for a technology product, and never watched a YouTube video about what I am buying. This is not an OWC drive dock.
Bob Zelin / Rescue 1, Inc.
http://www.bobzelin.com
Return to “Turbo Station Installation & Setup”
