Hard Drive(s) with QNAP Signature Detected
The system has detected that some of the installed hard drives have previously been used in a QNAP NAS. Select "Restore Factory Settings" to restore the system to its original settings (this will NOT delete any data on those hard drives.) Or select "Initialize System" to continue the installation process (this WILL delete all of the data on those hard drives.)
I chose the "Restore Factory Settings" option to keep the data on my hard drive.
It take a couple minutes and goes through the restore process, and then an automatic reboot and a few minute later I get a
Successfully Restored Factory Settings
If you cannot connect to the NAS administration page, please use QNAP Qfinder to locate your NAS.
Any ideas on how to get out of this loop?
