Hello community, I would like to describe a problem to you and hope that someone can help me, or has already experienced the same thing and found a solution.
1st Problem:
I connected to the web interface using Qfinder, initialized the hard drives, logged in and configured the drives as a RAID6 array. When I confirmed the settings with OK, the disks started to work and I lost the connection to the NAS. It rebooted and all hard drive LEDs are blinking green. But I can no longer connect to the web interface of the NAS via the Qfinder to see what going on.
2nd Problem:
I have the same firmware on the first NAS as on the second and tried a migration by installing the hard drives from the first NAS to the second in the correct order. When I turned on the NAS, the hard drives started to work. Then it rebooted and now the LEDs on the hard drives just blink. But I can't connect via Qfinder to see what's going on.
No matter whether I reinstall or migrate, after a reboot I lose the connection via the Qfinder and nothing happens anymore.
Is that normal? What does the NAS do? How long do I have to wait before I can reconnect? Been waiting an hour in both scenarios.
Maybe someone can help me or explain what is happening here. I would be very grateful.
Best regards, Tom
873AeU-RP
Re: 873AeU-RP
The device is broken.
Re: 873AeU-RP
If you still have warranty on it contact your POS or QNAP (depends on your jurisdiction)
