for an unknown reason (maybe the reboot yesterday) i can't connect to http/https anymore (no administration =()
ftp and ssh do work
i guess it's the httpd process that is not running, so my question is : how do i start it manually ?
(in case you think it's not the problem, thx for suggesting something else =))
thank you
nicolas
how to restart http server ?
Re: how to restart http server ?
up please !
just the command line...
#/etc/init.d/Qthttpd.sh start
#/etc/init.d/thttpd.sh start
hope this helps
hope this helps
QNAP 409TPro 1031T: MRTG (monitoring 409TPro and DD-WRT), Awstats, dnsmasq
Linksys WRT54G V2.2 DD-WRT v24SP1 VPN x 2 with home made 12V POE
Netgear GS608 with 9k jumbo frame
Panasonic C111 IPCam x 3
helped a whole great lot !!
thx for caring to answer =)
- OneCD
