Hi. This is what i'm interested in:
1. Cheap NAS for home entertainment use. Mainly for streaming HD video throughout home. So what I primarily need is the ability to handle HD video (BDrip) file streaming without hiccups. Min 8TB total storage support. Wouldn't want to spend more than $300 on this.
2. Some good Surveillance solution. Need an ability to monitor several cameras from PCs and TVs around the house as well as continuous recording.
If both of these can be integrated into a single unit then it's a plus.
Thank you.
Please suggest: home entertainment NAS and Surveillance
- Trexx
Re: Please suggest: home entertainment NAS and Surveillance
Hi Kuat,
Both of those functions can likely be integrated into a single unit, but not necessarily in the price point you are looking for. $300 for a NAS w/8TB is impossible. An 8TB NAS rated drive is $300/drive alone.
1) Define what your playback devices are going to be for your streaming? Streaming = sending data blocks to your playback device that will handle all the work. If you playback device can't handle the audio/video format of the BDrip, then the NAS has to do transcoding which is a much heavier load on the NAS. How many simultaneous streams are you looking at?
2) Just because a TV/PC has a camera in it, doesn't mean that you can necessarily access it via QNAP's surveillance software. Check the compatibility list here: https://www.qnap.com/en-us/compatibility/
Paul
UPS: CP AVR1350
UPS: CP AVR1350
- Been there, done that
if you use media players, they will only stream the file. no need for trascoding. they give you the most flexibility as to video/audio formats supported.
Production :
TVS-673 4.3.4 0387
4 X 3TB WD RED : 1 X 4TB HGST DESKSTAR R5
32GB
LAN-10G1SR-D, FiberHal for Cisco SFP-10G-SR
NETGEAR ProSAFE SS3300-28X
Backup :
TS-469L 4.3.4 0387
4 X 3TB WD RED R5
3GB
Located detached garage .. cheap offsite solution ...
2nd TS-469L awaiting drives and reassignment for front-line duty .......
TVS-673 4.3.4 0387
32GB
Backup :
TS-469L 4.3.4 0387
4 X 3TB WD RED R5
3GB
you can find by yourself from this web https://www.qnap.com/event/station/en/? ... e-choose-w
