I use it in an animation studio setting to serve up 3D assets, renders, and playback large video files. The gigabit network I currently have is the bottleneck.
My goal is to have performance that feels more like local or direct attached storage, but also have it redundant and available to the rest of the network.
I really only need one primary workstation to have that kind of speed. The rest are mostly headless render nodes that can access the files slower.
I've never used 10Gb or greater networking equipment, or it's Thunderbolt equivalent, so I'm torn as to which way I should go. I would love to see real world speeds approaching 1000MB/s read and write, and a relatively problem free and reliable storage solution. I am willing to pay for these features, but I don't want to overspend either. My purchase thoughts so far have been:
1. Wait for the TVS-1282T3 and connect via Thunderbolt 3 over USB-C
Pros:
- Theoretically should be the fastest connection @ 40Gb/s
- Latest generation i5 / i7 are options
- Could make use of QTIER setup with 2 tiers (SSDs & spinning disks) with M.2 Caching
- Low cost of upgrading existing network, though the TVS-1282T3 itself will likely be the most expensive NAS.
- Unsure how production ready TB3 networking will be.
- I would lose one entire TB bus on the workstation since it would be dedicated to the QNAP, assuming it works like the TB2 version
- High cost of TVS-1282T3
I include this option to reduce cost. TB2 should have sufficient bandwidth. I assume it would perform close to the TVS-1282T3, but I don't have any real world first hand experience with it, so if anyone does know what transfer speeds they are able to sustain I would be interested in hearing.
Online I see benchmarks of 950MB/s write, 750MB/s read for the TVS-871T if I was in that neighborhood it could be enough.
3. Go with a non-Thunderbold unit that has 10GbE out of the box, or add on a 10GbE / SFP+ card
Pros:
- Lower cost for the QNAP (I'm thinking TVS-882-i5-16G)
- Potential to connect more systems at high speeds down the road if I want to by just adding a network card in each
- Seems more industry standard to use traditional networking, rather than doing IP over Thunderbolt. Potentially less problems would pop up?
- Less theoretical bandwidth than TB2 or TB3
- Requires add-on 10Gb/s networking card for QNAP
- Requires add-on 10Gbps networking card for workstation
- Requires new switch with at least 2 10Gb ports
- I'm uncertain of the real-world sustained speeds over these connections
- If anyone has experience to share regarding Thunderbolt on the QNAP I would appreciate that. Is it reliable? Would it be a better option than traditional 10GbE or SFP+ if you are not trying to get an entire network of devices connected at those speeds?
- For those using 10GbE, what sustained transfer rates are you seeing on a regular basis?
- Finally, is 6th or 7th gen i5 processor enough to push 1000MB/s read and write? Should I only be considering i7 models?
