Dolby + Kodi
Dolby + Kodi
Do you anticipate that the Dolby licensing issue will be resolved, and that official mkv/Kodi/DTS/AC3 support will resume at some point in the future?
Re: Dolby + Kodi
doubt it ... just use the community version and be done with it
Re: Dolby + Kodi
Thanks for the reply. I have looked on the forums, and have seen that there is/was a version of Kodi made by a seemingly well respected user here though support for that version has (it seems) been discontinued in favor of a version from a French site. I'm not excited about having to rely on community projects that might appear and disappear in order to have basic multimedia capability. It worries me greatly that it isn't supported by default...in particular on something that will primarily be used for video streaming.
edit: I'm a rookie at this and don't relish the idea of scouring the internet and sifting through broken links to old versions that might or might not be compatible with my machine or current firmware. Am I imagining this as more of a problem than it is?
Re: Dolby + Kodi
Well I... don't even have that problem, because my QNAP does not even have any video/audio outputs
Either use the community KODI or ditch local playback,I use DLNA playback directly from my TV's or KODI from little playback boxes (android and WIN10) works just fine with no worries at all.
