Greetings,
I've been looking through a few possible choices from QNAP, Synology and ASUSTOR.
I plan on getting 4 x 8TB to use in the NAS and maximise the space with RAID-5 (24TB).
The purpose is for storage with regular but not 24/7 access.
For Synology, NAS with maximum single volume larger than 16TB tend to be above my budget with the DS416play being the cheapest at 400+.
For QNAP, the spec sheet doesn't mention anything so it is harder to figure out which is why I am here.
From what I gather, my options for current 4-bay NAS are TS-431P or TS-451A and TS-451+.
So from your experience, which NAS from QNAP would be suitable?
I would also consider an older model if it is worth it.
NAS with single volume larger than 16TB
Re: NAS with single volume larger than 16TB
if you want to be certain get a intel device...I know that arm still has issues with expanding past 16TB...so if you want to swap the drives for larger ones in the future,the X31p might give you grief
- Trexx
With a x64 compatible QNAP like the TS-451A/451+, under QTS 4.3.x you have a maximum Volume size of 250TB. Now that is not the RAID limit, but the volume carved within a storage pool limit.
See here:
http://docs.qnap.com/nas/4.3/cat2/en/vo ... newvolumes
See here:
Paul
UPS: CP AVR1350
UPS: CP AVR1350
oh so for double digit drivebay NAS units the 250TB limit might be approaching fast
- OneCD
dolbyman wrote:oh so for double digit drivebay NAS units the 250TB limit might be approaching fast
Maybe one day soon: https://arstechnica.com/gadgets/2016/08 ... ard-drive/
- Been there, done that
ohhhhh SEAGATE , the #1 name in RELIABILITY .....
Production :
TVS-673 4.3.4 0387
4 X 3TB WD RED : 1 X 4TB HGST DESKSTAR R5
32GB
LAN-10G1SR-D, FiberHal for Cisco SFP-10G-SR
NETGEAR ProSAFE SS3300-28X
Backup :
TS-469L 4.3.4 0387
4 X 3TB WD RED R5
3GB
Located detached garage .. cheap offsite solution ...
2nd TS-469L awaiting drives and reassignment for front-line duty .......
TVS-673 4.3.4 0387
32GB
Backup :
TS-469L 4.3.4 0387
4 X 3TB WD RED R5
3GB
- Johnno72
- Easy as a breeze
oh heck yes!!! 60TB SAS HDD @ $30 grand each though, yummy in deed. Imagining populating all 24 bays with these beauties.... now we really start talking about storage capacities such as Petabyte's, Exabyte's and Zettabyte's.
I better go grab a bib
OS: Win10 Professional v2004 OS Build 19041.388 x64
NAS: QNAP TS-EC2480U-RP 16G 24 Bay - Firmware: v4.4.3.1421 build 20200907. Updated from v4.4.3.1400 Build 20200817 Official
StoragePool / DataVol: Storage Pool 1 / DataVol1: Single 29.04TB - Thick Volume: 29TB
HDD's: Western Digital - Model: WDC WD4001FFSX-68JUN0 Red Pro NAS 3.5"
HDD Size: 4TB - HDD Firmware all HDD's: 81.00A81
RAID Configuration: RAID6 x 10, HotSpare x 1, ColdSpare x 1 - Network: 1GbE
UPS: CyberPower PR3000ELCDRT2U Professional Rackmount LCD 3000VA, 2250W 2U Line Interactive UPS
QNAP Hardware details required: viewtopic.php?f=5&t=68954
Remote Administration of: TVS-863+ 16G on UPS Cyberpower OLS1500E+RMcard205
