TS-253B 16GB supported ?
Interested in our products? Post your questions here. Let us answer before you buy.
depoverek
Post by depoverek »
Dear Support Team,
The datasheets for TS-253B on the website specify 2 x RAM slots (Max 8 GB)
On the Amazon website a version QNAP TS-253B-16GB is sold.
Is 16 GB RAM supported on the device?
Does the OS benefit from this additional memory?
Can the OS address this additional RAM?
In case it is supported, would it allow to run more virtual machines? 4 (16GB)?
Thanks for your support.
Moogle Stiltzkin
Contact:
Re: TS-253B 16GB supported ?
Post by Moogle Stiltzkin »
depoverek wrote:Dear Support Team,
on google i saw
16GB Kit (2x8GB) NAS TS-253B
and on the specification page
https://www.qnap.com/en/product/model.p ... 69&event=2
total memory slot: 2 x DDR3L SODIMM slots
(For dual-DIMM configuration, you must use a pair of identical DDR3L modules.)
maximum memory: 8GB
officially the
TS-253B-8G comes with 8GB DDR3L (2 x 4GB)
and the
TS-253B-4G with 4GB DDR3L(2 x 2GB)
hm... maybe you need to create ticket to confirm with them whether it can be self upgraded to 16gb or not.
https://helpdesk.qnap.com/
Anyway, Crashplan likes a lot of ram. For every 1tb they recommend having 1gig of ram or something like that. So for backing up 10+ tb, more ram the better :) thats the one app i know that uses up a lot of ram.
[youtube=]dR4e4cn5U8o[/youtube]
NAS
Network
Resources
Don
Post by Don »
Without providing details on the 4 VMs you want to run it is impossible to say if 253B will support them. It is more than just a memory consideration.
schumaku
Contact:
Post by schumaku »
The same as with many similar questions on some Intel architecture QNAP NAS before, ie. TS-x51, TS-x53, ... QNAP will not claim 16 GB supported, because of Intel does not support more than 8 GB on the Intel® Celeron® Processor J3455. Neither QNAP nor Google, nor Youtube, nor eBay, nor whoever can provide a different answer: Probably workable (at your own risk) is not the same like supported.
sanke1
Post by sanke1 »
It works. 2x8GB modules. It is even detected correctly as 16GB in QNAP. However Intel themselves do not support this memory configuration. God knows why.
kherr4377
Been there, done that
Post by kherr4377 »
works = yes
supported = no
keep your original memory, you may need it to get support, especially if you have to send it in
Production :
TVS-673 4.3.4 0387
4 X 3TB WD RED : 1 X 4TB HGST DESKSTAR R5
32GB
LAN-10G1SR-D, FiberHal for Cisco SFP-10G-SR
NETGEAR ProSAFE SS3300-28X
Backup :
TS-469L 4.3.4 0387
4 X 3TB WD RED R5
3GB
Located detached garage .. cheap offsite solution ...
2nd TS-469L awaiting drives and reassignment for front-line duty .......
Packetboy
Post by Packetboy »
sanke1 wrote:It works. 2x8GB modules. It is even detected correctly as 16GB in QNAP. However Intel themselves do not support this memory configuration. God knows why.
Hi mate could you please tell me the exact 16gb kit your using for your TS-253B? I am about to buy one and defo want 16gb of ram as well...
Cheers
sanke1
Post by sanke1 »
Any 2x8GB DDR3L RAM, 1600/1866 MHz, SO-DIMM modules will work. I preferred Kingston DDR3L 1600 Mhz module for best compatibility.
TPLINK
Getting the hang of things
Post by TPLINK »
TS-2888X-W2133-64G 10Tb WD-Red Qsubsonic, Storage, backup
Acer Aspire 16Gb 8th gen. I7 Windows 10 Home 64Bits
1Tb free Stack
Don
Post by Don »
TPLINK wrote:any news about this?
I want to replace my TS-253 8Gb pro by a Ts-253B 8Gb, and upgrade the 8Gb to 16Gb
What news are you looking for? It has been stated many times that it works.
schumaku
Contact:
Post by schumaku »
As long as Intel has the SoC specs set to 8 GB, QNAP can't officially support more. Very unlikely this will change for a released SoC btw,
stefaanbolle
Post by stefaanbolle »
Crucial 8GB (CT2KIT102464BF160B) will work
TPLINK
Post by TPLINK »
stefaanbolle wrote:Crucial 8GB (CT2KIT102464BF160B) will work
thanks
1Tb free Stack
Poincare
First post
Post by Poincare »
TPLINK wrote: Thu Sep 13, 2018 10:29 pm
thanks
Bro, did you get this RAM kit to work on the QNAP?
chef1
Post by chef1 »
schumaku wrote: Thu Sep 13, 2018 4:10 pm As long as Intel has the SoC specs set to 8 GB, QNAP can't officially support more. Very unlikely this will change for a released SoC btw,
And if you know that Intel doesn't retest for limits as larger memory modules become available, you don't know what Intel does support. The Intel CPU capabilities may report different values as the Intel data sheets. The CPU may even support a different memory type but the main board will not.
sanke1 wrote: Sat Aug 19, 2017 2:32 am Any 2x8GB DDR3L RAM, 1600/1866 MHz, SO-DIMM modules will work. I preferred Kingston DDR3L 1600 Mhz module for best compatibility.
I don't think so. QNAP devices are selective. Not every latency supported by memory modules match the requirements of QNAP devices. Using the same latency as the modules offered by QNAP shop should work. A slightly different latency might work, eventually dependant on the memory module cooling. More latency difference is likely NOT to work.
QNAP TS-431P QTS 4.4.1.
QNAP TS-453Be QTS 4.4.1.
QNAP TS-873 QTS 4.4.1.
Locked
Return to “Presales”
