I'm consindering the mini, but it's unclear how the drives are cooled. As far as I can tell, there is no fan like there is on the regular 4-bay models at the back.
Are they simply supposed to be cooled by convection out of the top of the unit? That would seem inadequate.
No reviews or videos that I've found even mention this potential issue.
TS-453B Mini cooling?
- schumaku
Re: TS-453B Mini cooling?
Not an issue of course - as there is a fan. Look ie. there -> https://www.eteknix.com/qnap-ts-453-min ... -review/2/Decipher wrote:No reviews or videos that I've found even mention this potential issue.
Thanks, that's helpful. However, it's not evident how intake-exhaust is handled, as the box looks pretty solid, and a sideways fan directly opposite a solid surface wont be that effective.
From what I can tell there is a tiny intake grate on the bottom at the front - and an exhaust grate at the top back but under the magnetic lid. It all sounds very restricted air-flow'y.
- schumaku
The air intake is around the top, the magnetic lid is not closed. It's not a sideways fan - it's a radial fan with the inlet oriented to the HDD trays...Decipher wrote:Thanks, that's helpful. However, it's not evident how intake-exhaust is handled, as the box looks pretty solid, and a sideways fan directly opposite a solid surface wont be that effective.
...and the outlet stream does flow out to the lower side, where a SoC (CPU, GPU) cooler is having his ribs into the airstream, too.Decipher wrote:From what I can tell there is a tiny intake grate on the bottom at the front - and an exhaust grate at the top back but under the magnetic lid. It all sounds very restricted air-flow'y.
Beautiful industrial design for a home user device it is. Of course, installing heat (== power) intensive high RPM storage blocks is not an option. This enclosure design is in the market since summer 2015 (starting with the TS-453mini), the mini NAS is very quiet for a four bay.
Thanks for the clarification, I'll give it a second look
