I currently have a TS-470 Pro 4 bay.
The drives are not encrypted.
I use this NAS as media center.
1st - Can I backup my settings from my TS-470 Pro and restore them on a TS-253b?
2nd - Can I pull the 4 drives from my TS-470 Pro and plug them in the TS-253b without having to make any changes?
Thank you for any help.
Migrating to new TS-253b
TS-453be with 2x WD 3TB Reds and 2x WD 4TB Reds
TS-470 Pro with 2x WD 8TB Reds and 2x WD 10TB Reds
QTS 5.0.0.1986
Windows 11 Pro
QTS 5.0.0.1986
Windows 11 Pro
Re: Migrating to new TS-253b
normally I would say .. check system migration in the manual ..
but what config have the 4 drives been in ? .. if raid ..unclear how you want to fit 4 drives in a 2 bay unit
I'm very sorry, this is the TS-453B.
So I'm going from a 4 bay unit to a new 4 bay unit.
QTS 5.0.0.1986
Windows 11 Pro
QTS 5.0.0.1986
Windows 11 Pro
then just check the manual for system migration
- shadowsports
Hi Fubie,
Have you migrated yet? Do you mind me asking how you like the 453B? I'm getting ready to replace my 219P II and was looking at the 453B with 8GB.
QNAP TVS-473e 4x 4TB WD REDs - RAID5 - 2x 500GB M.2 (SSD Caching) - 32GB RAM - FW 5.1.0.2466
QNAP TS-219P-II 4TB WD REDs - FW 4.3.3.2420 >>>> Both Protected By UPS <<<<
Z390 AORUS PRO (F10)\850w, 9900K, 32GB GSkill TriZ RGB - 16-18-18-38, RTX 3080Ti FTW3 Ultra, 960 Pro_m.2, W11 Pro
Z370-HD3P (F5)\750w, 8350K, 8GB LPX 3200 - 16-18-18-36, GTX 660 FTW, Intel SSD, W11 Pro
Z97X-UD5H (F8)\Corsair RM850w, 4790K, 16GB Vengeance, GTX970 FTW SC 4GB ACX 2.0, 850 Pro's RAID0, W10 Pro
Phone - Pixel8
KaPOW!
Phone - Pixel8
KaPOW!
I have not gotten one yet. The Holidays are making sure of that. I will probably pull the trigger after tho.
QTS 5.0.0.1986
Windows 11 Pro
QTS 5.0.0.1986
Windows 11 Pro
- shadowsports
The 453B is a downgrade from a 470 Pro in many ways, but I understand why you are moving. The 470 is EOL like my 219P II next month. We'll get security updates till 2020 but that's it.
Phone - Pixel8
KaPOW!
Phone - Pixel8
KaPOW!
